    Intersect two Component Instances
    7 Posts 3 Posters 492 Views 3 Watching
    • C
      chochmah
      Hi Forum,
      I'm going crazy trying to intersect two component instances.
      I want to intersect a instance of the component Model and a instance of the component Plane and store the intersecting edges in intersection_edges in the Plane Component. I fail miserably probably because I don't really understand how the transformations work on instances. Any Help would be really great, I already spend more than 2 hours trying to get this to work.
      entities.each do |s|
       if s.definition.name=="Model"
        $model_tr = s.transformation
        $entities_model=s.definition.entities
       if s.definition.name=="Plane"
        $plane_tr = s.transformation
        $entities_plane=s.definition.entities
      intersection_edges = $entities_plane.intersect_with(false,$model_tr.inverse ,$entities_plane,$plane_tr,false,$entities_model.collect)
      Thank you very much!
      • TIGT
        First off please don't use $ variables - one day they'll clash with other's code and cause disasters... use @ ones if your code spans 'def' methods...
        Also calling your component/instance 'model' is just confusing as that's normally used for 'the model' itself ! And 'plane' refers to something that a face has... ๐Ÿ˜’
        Make references to the two 'containers' instead of their entities !
        Say @xmodel and @xplane - we can deal with the entities later...
        Then try...
        intersection_edges = Sketchup.active_model.active_entities.intersect_with(true, @xplane.transformation.inverse , @xplane.definition.entities, @xplane.transformation.inverse , true, [@xmodel, @xplane])
        Note that 'intersection_edge's might also include new faces etc...
        This is untested ๐Ÿ˜ฎ - the principle is that you intersect the objects where they are and put the results into the desired container...
        Try messing around with the .inverse methods if the intersection id not where it's required...
        • C
          chochmah
          Thanks for the quick reply.
          I replaces the global variables and renamed the instances.
          model = Sketchup.active_model
          entities = model.entities
          instance_body=0
          instance_bulkhead=0
            instance_body=s;
           if s.definition.name=="BPC"
            instance_bulkhead=s
          intersection_edges = Sketchup.active_model.active_entities.intersect_with(true, instance_bulkhead.transformation.inverse , instance_bulkhead.definition.entities, instance_bulkhead.transformation.inverse , true, [instance_body, instance_bulkhead])
          I tried every possible combination of inverse and non-inverse but there's always strange stuff happening. It does only work if both instances are not transformed at all so I guess it must have something to do with the transforms.
          Thank you very much
          http://666kb.com/i/c6z16r4fzyihtjhbr.jpg
          The lines are the intersection_edges
          • TIGT
            It's quite possible to get this to work... unfortunately I don't have a spare moment to look at it right now in any detail... have you tried permutations of all .transformation/.transformation.inverse to see what happens... This MIGHT work - assuming there are only 2 active entities !! Perhaps dump the 'inverse' = untested...
                entities = model.active_entities
                instance_body=nil
                instance_bulkhead=nil
                  instance_body=s
                 elsif s.definition.name=="BPC"
                  instance_bulkhead=s
                return unless instance_body && instance_bulkhead
                tr=Geom;;Transformation.new()
                intersection_edges = entities.intersect_with(true, tr, instance_bulkhead.definition.entities, instance_bulkhead.transformation.inverse , true, [instance_body, instance_bulkhead])
            • C
              chochmah
              Thank you! This works indeed. I just had to remove the one ".inverse".
                  intersection_edges = entities.intersect_with(true, tr, instance_bulkhead.definition.entities, instance_bulkhead.transformation, true, [instance_body, instance_bulkhead])
              The one remaining problem is now that there are usually more than two entities and this intersects all of them with the instance_body including the instance_body itself. Do you have a quick tip how to restrict the intersect to the two objects instance_body and instance_bulkhead?
              Thank you very much for your help, it's much appreciated
              • sdmitchS
                sdmitch
                Here is another shot at it for you to try
                model_component=nil;plane_component=nil
                cmps=entities.find_all{|c| c.class==Sketchup;;ComponentInstance}
                cmps.each{|c| (model_component=c;break) if c.name=="Model"}
                cmps.each{|c| (plane_component=c;break) if c.name=="Plane"}
                if model_component and plane_component
                 intersection_edges=plane_component.definition.entities.add_group;intersection_edges.name="Intersection_Edges"
                 plane_component.definition.entities.intersect_with(true,plane_component.transformation,intersection_edges.entities,intersection_edges.transformation,true,model_component)
                 intersection_edges.transform! plane_component.transformation.inverse
                else
                 UI.messagebox "Both components not found"
                http://sdmitch.blogspot.com/
                • C
                  chochmah
                  Thank you. That solved the last Problem with the intersect.
                  you guys have been very helpful@TIG,sdmitch Thanks a thousand
