    Align Plugin Project
    6 Posts 3 Posters 545 Views 3 Watching
    • F Offline
      fatihbarut
      Hi guys.
      I am trying to make an alignment plugin.
      I want to align components and groups using their one face or edge.
      which approach you think I should use?
      I think I can align faces and edges easly however I dont know how I can let the other faces and edged of group follow that face...
      • mitcorbM Offline
        mitcorb
        Didier Bur has developed both a 2d and a 3d Align tool. Perhaps study these?
          http://forums.sketchucation.com/viewtopic.php?t=20233
          • F Offline
            fatihbarut
            I already saw that. That is not the solution. It works with groups and components I need much more complicated one.
            it must use just one face or edge of a component as pivot point for align.
            And also need to calculate normal of the faces or angles between faces.
            And much more...
              Can you describe it with screenshots? If you could describe and visualize the desired process it's be a lot easier to lay out a design scheme for the code.
              • F Offline
                fatihbarut
                here is the video explaining the idea
