    [Code] (Iterating) Finding Definitions
    4 Posts 2 Posters 765 Views 2 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      [ Code ] (Iterating) Finding Definitions
      # An example prepared by Dan Rathbun. (2012)
      # Version ; 0.3.0
      module Author ### <-- replace with your top level namespace
        module Util ### <-- change sub-module name to suit
          class << self # proxy class
            public
            def find_defintions(ents_array)
              defns = []
              ents_array = ents_array.to_a
              unless ents_array.empty?
                for e in ents_array
                  if e.is_a?(Sketchup;;ComponentInstance)
                    defns << e.definition
                  elsif e.is_a?(Sketchup;;Group)
                    defns << e.entities.parent
                end # for
              defns.uniq!
              return defns
            def find_nested_defintions(ents_array)
              defns_all = [] # the array to return
              return defns_all if ents_array.empty?
              defns_chk = find_defintions(ents_array)
              until defns_chk.empty?
                defn = defns_chk.pop
                defns_all.include?(defn) ? next ; defns_all << defn
                defns_new = find_defintions(defn.entities.to_a)
                next if defns_new.empty?
                for d in defns_new
                  unless defns_all.include?(d) || defns_chk.include?(d)
                    defns_chk << d
                end # for
              end # until
              return defns_all
            def find_defintions_from_selection(
                all = false,
                sel = Sketchup.active_model.selection
              sel = sel.to_a
              return defns_all if sel.empty?
              if all
                find_nested_defintions(sel)
              else
                find_defintions(sel)
              return defns_all
          end # proxy class
        end # submodule
      end # toplevel module
      Untested as of: 2012-08-25 : Use at own risk. No warranty.
      πŸ’­
      I'm not here much anymore.
        Dan Rathbun
        REVISED: (v0.2.0)
        • condensed find_nested_defintions() a bit.
        • replaced all .each iterators with for ... in loops for speed.
          Shouldn't it be return defns.uniq which would always return a unique array of defns; whereas return defns.uniq**!** returns a unique array of defns only IF there were duplicates in the original, BUT ' nil' if there were no duplicates in the original...
            Dan Rathbun
            Yes it should, and now is. Updated the code.
            (I was uniq!'ing in the calling methods, and at the last moment replaced several in those methods, by adding the .uniq! to the return statement. I did think about which uniq to use, for a split-second, and didn't want to create a new array object, so I added ! to the end. That's what happens when ya' rush.)
            Thanx for the check TIG!
