    [Ruby idea] Click scale
    7 Posts 2 Posters 618 Views 2 Watching
    • R
      rv1974
      First off about the problem itself:
      Very often using the built-in scale tool (especially with long thin objects)one needs to zoom really close to find the exact grip to scale; then make excessive scrolling out to see the destination(reference) point. It's very irritating!
      So here comes the concept:
      1. with preselected object(s) one hits the shortcut, and types Z for non uniform scale in Z direction (X and Y for other directions respectively).
        Note: a) the plugin should use the item's axes, not the current UCS.
        b) no modal windows, the script runs in background.
        c) some respected ruby writers say it's impossible to make temporal override for the X,Y,Z keys. But I've seen it in Thomthom's
        Vertex tools, if the memory serves me right. So I really don't know what to think about this
        2. Then 2 clicks: the first one (say on the object itself), the 2nd one- the destination point. That's it.
        (Alternatively clicking with SHIFT key would produce the uniform scale)
        Edit: In case of Z scaling for instance: Clicking on the upper portion of the object would result non-uniformal scaling in the upwarddirection. The object's insert point would stay untouched. Clicking on the lower portion would scale downward and etc.
        Edit2: It should be an 'external' tool. I mean no need to enter the 'edit item' mode to choose the edge.
      What do you think?
      • thomthomT
        @rv1974 said:
        c) some respected ruby writers say it's impossible to make temporal override for the X,Y,Z keys. But I've seen it in Thomthom's Vertex tools, if the memory serves me right. So I really don't know what to think about this
        Not quite the same. I made Vertex Move activate the native Move tool if the user isn't in vertex mode. That means the user can re-assign the shortcut key for native Move to Vertex Move and it'll work seamlessly. But not that the user has to remap the shortcuts for this to work.
        But there really is no automated way to intercept keys that is used in shortcuts.
        • R
          rv1974
          I see. Maybe as workaround the user could initially click on the corresponding edge (it shold be hilighted in the awesome Fredo's style) to
          choose the desired direction.
          • thomthomT
            Or, I make the Gizmo from Vertex Tools 1.1 standalone....
            • R
              rv1974
              β˜€ Sounds too good to be true.
              P.S. I've added some editing in the topic start.
              • R
                rv1974
                What exactly do you mean? Would it be an independent tool or part of the Vertex tools pack?
                I'd prefer the first option because I need it for commponent\group scaling not for the vertex\polygon modifying.
                • thomthomT
                  Yes, independent from Vertex Tools.
