    Maxwell (fire) plugin rendering HELP
    3 Posts 3 Posters 1.5k Views 3 Watching
      Architect 123
      I am usiing Sketchup Professional and have the Mawell plugin (Fire) how do I go about using the IES file for interior lighting effects? How does one go about setting say a recessed down light in a room and be able to produce a certain amount of light?
      • brewskyB Offline
        brewsky
        We too are using the Maxwell fire plugin at work, great renderer!
        I didn't do any interiors yet, so I'm not much help here.
        What about the maxwell forum? Might be a better place for these specific plugin settings?
        http://www.maxwellrender.com/forum/viewforum.php?f=107
        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
          DavidHughesArchitect
          You need to do the following...
          first make a shape to be your light and apply a unique material to it...call it IES emitter or something useful
          next in the Maxwell Scene Manager using the materials tab assign an IES emitter material to this material you just created in SU.
          You should see different previews of the various IES lights that came with the Maxwell plugin.
          If you don't see any light try reversing the faces ...
          if this doesn't work try increasing the power or wattage of the IES light...however this is just to see if it is working
          Essentially Maxwell works just like a camera so for interiors lit by lights you need to increase your exposure which is done by changing the EV value in the Maxwell scene manager..
          as you do this the FIRE render should update and allow you to tweak the settings until you get the light level you want
