    Trick with the Rotate Tool
    12 Posts 9 Posters 1.2k Views 9 Watching
    • Jean LemireJ Offline
      Jean Lemire
      Hi folks.
      I am not sure that this is widely known, especially by beginners.
      See this SU file for ideas:
      Rotation along any edge even a remote one.skp
        d12dozr
        πŸ‘ πŸ‘
        Excellent tip, Jean! Sketchup's inferencing is definitely underestimated.
        http://goo.gl/f7ooYh
          V6 or V7 file? 😳
          • Mike LuceyM Offline
            Mike Lucey
            Thanks Jean, yet another tip to add to the Jean Lemire's 'Just Ideas' collection over over 120 tips and tricks πŸ‘
            Looking forward to having a few beers with you soon πŸ˜‰
            • cottyC Offline
              cotty
              Nice one, thank you! I've added it to the DUH!s...
              my SketchUp gallery
                Jean Lemire
                Hi Pilou, hi folks.
                V7
                  ArCAD-UK
                  @d12dozr said:
                  :thumb: πŸ‘
                  +1 Thanks Jean. SU looks so simple yet the tricks just keep coming. I didn't know you could get a parallel inference. πŸ‘
                    Seems it's always V8 format! πŸ˜‰
                    But finally i found a computer with the V8 installated at my next door neighbor! πŸ’š
                    Yes cool trick πŸ˜„
                    But see this epic thread about the insufficiency of the Rotate tool inferency! πŸ€“
                      raineysky
                      Bookmarked!!! Super Cool trick Jean. Thanks for sharing.
                      Paul
                        Ben Ritter
                        Can't get it to work. Am I missing a step? At what point do you align the bottom of the protractor?
                        If I keep holding the LMB after I pick the rotation point, the protractor wants to rotate around an axis other than the blue.
                        • cottyC Offline
                          cotty
                          The rotation around the blue axis is not the goal. It is the combination of
                          • define the rotation axis "the right way" (one description from Gaieus here)
                          • the linear parallel inference (e.g. here)
                          -> You can use the inference system from Sketchup while defining the roation axis
                          my SketchUp gallery
                            Len_Corwin
                            Unclear what B and C refer to: the points adjacent to A on the ground? Is the solid resting on a triangular face? Another view would help clarify its shape.
                            Is one supposed to be able to carry out the indicated operations on the provided file? Perhaps add the result of the rotation.
