    Change Units in dynamic components
    1 Posts 1 Posters 516 Views 1 Watching
    • G
      Goele
      Hi!
      I've made a custom attribute called "weight" with this formula: =LenZ*6.2/100 and the settings like in the image below.
      However... When I click component options, the weight is indeed in kg but converted from pounds. Which means that the number isn't right.
      Does anyone know how to change the weight unit in a dynamic component?
      Thank you!
      Kind regards!
      Settings
