    Array woes
    4 Posts 2 Posters 254 Views 2 Watching
    • C
      Cheez
      Hello,
      I have the following methods in a class, the idea being that the user is to click various points on a model and the tool knows the user selection is finished when a click matches the first click, so if they were tracing a square the 5th click will be the same as the first and trigger the puts(). However the puts() is always triggered by the second click even when it is definately not clicked in the same place.
      Any advice much appreciated.
      def initialize
         @ip  = nil
         @pts = []
      def activate
         @ip = Sketchup;;InputPoint.new
      def onLButtonUp(flags,x,y,view)
         @ip.pick(view,x,y)
         if(@ip == @pts[0])
            puts("Start Point Clicked")
         else
            @pts << @ip
      • TIGT
        Try saving the input point as a proper point3d object, using '.position'
           @ip.pick(view,x,y)
           if @pts[0] && @ip.position==@pts[0]
           else
              @pts << @ip.position
        • C
          Cheez
          Thanks works like a charm.
          I take it you added the @pts[0] to the test because @pts[] is not initialized with anything?
          • TIGT
            Yes, it'd return an error or if @ip1 is nil then it might be seen as equal to an empty @pts[] ?
            If you are testing something that might be nil it's a good idea to check it exists first...
