    Problem Intersecting
    3 Posts 2 Posters 166 Views 2 Watching
      Cubcrafter
      I am having problem intersecting the two attached shapes.
      Intersect will draw the shape of the cylinder on the long curved shape but I can not delete the hole that is created in the long curved shape.
      I do not know if I am doing something wrong or is it the file.
      Any help would be appreciated.
      Working on plans of a full scale Nieuport N11 aircraft that we are cutting kits with our laser to build at 1/2 scale.
      This is the cockpit cutout in the turtle deck.
      Thanks,
      Larry
      FullScaleMaster3View7.skp
      • charly2008C Offline
        charly2008
        Hi Larry,
        I've played around a bit. I've kept the group and used ThomThoms Cleanup, then the intersection worked. I don't know why!
        Charly
        FullScaleMaster3View7-3.skp
          Cubcrafter
          Thanks Charly,
          I will take a look at ThomThoms Cleanup tool.
          Here the part is located. This just shows the exterior layouts of the aircraft before I work on the internal structure.
          Thanks,
          Larry
