    EntitiesObserver and Attributes - work around
    21 Posts 3 Posters 3.1k Views 3 Watching
      rvs1977
      Hi!
      Im trying to figure out how to use the add_observer method on the entities in a group, and saw TTs list (url below)
      http://www.thomthom.net/software/sketchup/observers/#ViewObserver
      Here my worst nightmare came through... The Sketchup::EntitiesObserver - onElementModified(entities, entity) dont work. Just as I had experienced myself.
      What I try to accomplish (see the code below), is to keep track of the area of a specific face, named yv_face_area (green color). Initially I have set an attribute to the rsgroup (which contains the yv_face_area) set_attribute("rsdict, "area", area). It seems to work fine.
      But, as mentioned, the onElementModified method dont seems to work.
      Anyone haves an idea how to work around this problem?
      snippet:
      mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      class MyEntityObserver < Sketchup;;EntityObserver
          def onEraseEntity(entity) #this work
              UI.messagebox("onEraseEntity; " + entity.to_s)
      end #class
      class MyEntitiesObserver < Sketchup;;EntitiesObserver
          def onElementModified(entities, entity) #dont seems to work
              UI.messagebox("onElementModified; " + entity.to_s)
          def onEraseEntities(entities) #this seems to work
               UI.messagebox("onEraseEntities; " + entities.to_s)
          def onElementRemoved(entities, entity_id) #dont seems to work
              UI.messagebox("onElementRemoved; " + entity_id)
          def onElementAdded(entities, entity) #this seems to work
              UI.messagebox("onElementAdded; " + entity.to_s)
      end #class
      pts = []
      pts[0] = [ 0, 0, 0]
      pts[1] = [ 1000.mm, 0, 0]
      pts[2] = [ 1000.mm, 1000.mm, 0]
      pts[3] = [ 0, 1000.mm, 0]
      pts[4] = [ 0, 0, 1000.mm]
      pts[5] = [ 1000.mm, 0, 1000.mm]
      pts[6] = [ 1000.mm, 1000.mm, 1000.mm]
      pts[7] = [ 0, 1000.mm, 1000.mm]
      5.times do |i|
          rsgroup = ent.add_group
          rsgroup.entities.add_face pts[0..3]
          yv_face_height = rsgroup.entities.add_face pts[4..7]
          rsgroup.entities.add_face pts[0], pts[3], pts[7], pts[4]
          rsgroup.entities.add_face pts[3], pts[2], pts[6], pts[7]
          rsgroup.entities.add_face pts[1], pts[2], pts[6], pts[5]
          yv_face_area = rsgroup.entities.add_face pts[0], pts[1], pts[5], pts[4]
          yv_face_height.pushpull rand(1000.mm)
          yv_area = yv_face_area.area.to_m.to_m
          yv_face_area.material = (0xAADEAA)
          rsgroup.set_attribute "rsdict","area", yv_area
          yv_face_area.set_attribute "rsdict", "area2", yv_area
          point = Geom;;Point3d.new (1100.mm * i, 0, 0)
          t = Geom;;Transformation.new point
          rsgroup.transform! t
          rsgroup.add_observer(MyEntityObserver.new)
          rsgroup.entities.add_observer(MyEntitiesObserver.new)
      end #times_do
      ent.each do |o|
          point = Geom;;Point3d.new (0, 1100.mm, 0)
          o.transform! t
      end #each_do
      i = 0
      ent.each do |o|
          attr = o.get_attribute "rsdict","area"
          if attr
              UI.messagebox "Attr - Area; " + attr.to_s + " m² - n; " + i.to_s
              i = i + 1
      Get a Ruby
        http://www.thomthom.net/software/sketchup/observers/#EntitiesObserver
        Here I noted that EntitiesObserver.onElementModified is working in SU8...
        btw - what are you planning to do on the event? Make model changes? I found that can often mess up other scripts or even crash SketchUp.
          Also, when testing observer I don't use messageboxes as the silly manual does. If the observer trigger many events you'll be stuck with clicking messageboxes. I prefer to use puts - or even win Win32API to output to DebugView.
            rvs1977
            When a wall is resized I want the walls area-attribute to update. Thats basically what Im trying to do.
            Great to know that SU8 might work.
            About using put, I dont know how to use it? Is it possible to use it with Alex Screyers Ruby Editor? I have tried without any output. Im interested to know more about Win32Api. Is it something I need to download?
            Get a Ruby
            • Dan RathbunD Offline
              Dan Rathbun
              It is is puts, not "put". (It is short for "put string".)
              puts() outputs to STDOUT so you must have some console open before you call it. You can use the built-in Ruby Console that comes with SketchUp, from the Window menu. (Or you can use also Alex's WebConsole. It is your choice.)
              You do not need to worry about the Win32API, or win32-api libraries, at this time. (Using them is at the advanced level.)
              If you are developing plugins, you should be using the latest version of SU 8, not 7. (You can still have 7 installed if you need to import/export DWG files. But that is really all you should be using 7 for.)
              I'm not here much anymore.
                rvs1977
                Next problem:
                When deleting a group, and undoing - it looses all the observers. 👎
                Well, have to look at that tomorrow.
                Luckily it keeps the attributes as far as I can see...
                Dan, ok I stay away from win32api for a while 😄
                Get a Ruby
                  rvs1977
                  Think I found a usable solution to this problem:
                  (It only works in SU8+)
                  1. Add EntitiesObserver to each Entity with the attributes("rsdict","area")
                  2. Keep the EntitiesObservers when undoing a deleted group
                  3. Keep the EntitiesObservers when copying a group.
                  4. Add EntitiesOberservers to each group with the attributes ("rsdict", "area")
                  The solution seems to be simple: - Every time something happens (like undo or change, etc.) the executed observer iterates through each entity and, in my case, when it finds an entity with the attributes ("rsdict", "area") it simply add_observer(MyEntitiesObserver.new).
                  It can be testet with the two pieces of codes below.
                  In this example it messures the area of the green face, when you pushpull the red face at the top.
                  In the first codepiece it draws some boxes and adds some attributes, but dont add any observers. Try to run the code a few times so it will produce a number of boxes.
                  pts = []
                  pts[0] = [ 0, 0, 0]
                  10.times do |i|
                      yv_face_length = rsgroup.entities.add_face pts[1], pts[2], pts[6], pts[5]
                      yv_face_area.material = (0xAADEAA) #green
                      yv_face_height.material =(0x8811FF) #red
                      yv_face_area.set_attribute "rsdict", "yv_face_area", yv_area
                      yv_face_length.set_attribute "rsdict", "yv_face_length" , 0
                      yv_face_height.set_attribute "rsdict", "yv_face_height", 0
                  end #times_do
                  ent.each do |o|
                      o.transform! t
                  end #each_do
                  Second piece of code: - Here it add the observers. Every time the code is executed it will asign the observers. And it seems like it doesnt matter how many times you do it.There will only be one observer for each entity.
                  class MyModelObserver < Sketchup;;ModelObserver
                      def onTransactionUndo(model)
                          #UI.messagebox("onTransactionUndo; " + model.to_s)
                          Sketchup.active_model.entities.each do |o|
                              if attr
                                  o.add_observer(MyEntityObserver.new)
                                  o.entities.add_observer(MyEntitiesObserver.new)
                  end #MyModelObserver
                  #Adding ModelObserver - Undo
                  Sketchup.active_model.add_observer(MyModelObserver.new)
                      #def onEraseEntity(entity) #this work
                          #UI.messagebox("onEraseEntity; " + entity.to_s)
                      #end
                      #def onChangeEntity(entity)
                          #UI.messagebox("onChangeEntity; " + entity.to_s)
                      #end
                  end #class
                          attr_length = entity.get_attribute "rsdict", "yv_face_length"
                          attr_height = entity.get_attribute "rsdict", "yv_face_height"
                  		if attr_length
                              entities.each do |i|
                                  attr_area = i.get_attribute "rsdict", "yv_face_area"
                                  if attr_area
                                      yv_area_new = i.area.to_m.to_m
                                      #UI.messagebox "Length changed - area before; " + attr_area.to_s + " m² - area after; " + yv_area_new.to_s + " m²"
                                      i.set_attribute "rsdict", "yv_face_area", yv_area_new
                                  end #attr_area
                              end #each do
                          end #if attr_length
                          if attr_height
                                  if attr_area
                                      UI.messagebox "Height changed - green face - area before; " + attr_area.to_s + " m² - area after; " + yv_area_new.to_s + " m²"
                                  end #attr_area
                              end #each do
                          end #if attr_height
                      end #onElementModified_end
                  end #class
                  i = 0
                  ent.each do |o|
                      if attr
                          i += 1
                  UI.messagebox "number of boxes; " + i.to_s
                  Get a Ruby
                    There is still the problem that you modify the model on observer events. When you do that you interfer with any operation that is going on - which might be in the middle of a start/commit operation of another plugin or native tool. You'll be adding to the Undo stack - causing unexpected behaviour when the user expects to undo their last operation but instead the undo is your injected attribute change.
                    Model change at observer events may cause bug splats.
                      rvs1977
                      Im not sure how to do it yet, but I think a solution could be to remove the observers, when editing the group, and adding the observer again when finished.
                      It seems to be very quick to add observers to ALL the entities in the model, and its not possible to add more than one observer to each entity, so you dont have to take care if the entity allready has got one.
                      Get a Ruby
                        Strongly recommend you use observers sparsely. Also what you do within the events. Some events trigger many times a second - and that mean you can easily bog down SketchUp.
                        Yes you can add more than one observer.
                          rvs1977
                          What I meant was, if you do like this:
                          (adding 3 identical observers to one entity)
                          Code:
                          mygroup.entities.add_observer(myEntitiesObserver.new)
                          it will only have one myEntitesObserver attached to mygroup. - not three. That means its easier to handle... You dont need to check if its allready added, its faster just to add new one to every entities.
                          Yes you can add more observers to one entity eg. MyEntitiesObserverWatchFaces and MyEntitiesObserverWatchEdges
                          Get a Ruby
                            Not correct. For each new instance of your observer class you attach you add an observer:
                            Here I first drew one line. Then added another observer. When I draw a second line I get two observer triggering - and they are both of the same class.
                            However, if you attach the same instance of your observer to the same element, then it's no extra observers added:
                            Here I only ever get one observer triggering - because I'd only ever attached a single instance.
                            I store the reference to the observers I use. Then I remove it - just to be sure.
                            ` @entities_observer = myEntitiesObserver.new
                            def self.observers
                            mygroup.entities.remove_observer( @entities_observer )
                            mygroup.entities.add_observer( @entities_observer )
                            end`
                            Just to be sure
                              rvs1977
                              Ok, maybe you are right, but to me it seems like it only triggers once, even though I have attached it many times in a row.
                              Could it be that it is overwritten each time its attached?! As far as I can see its not possible to see which observers is added in the model.
                              If you try the code I have attached above you can what I mean...
                              (Run the first code a couple of times to get some boxes without observers, then run the second code as many times you want, and the observers only triggers once)
                              Get a Ruby
                                If you attach the same instance. But if you do like in my second example, you keep a reference to an instance and use that reference when you attach observers it won't create duplicates.
                                Correct, there isn't.
                                  Got a sample model with "Boxes"?
                                  What do you do to trigger the events?
                                  Btw - you know that model.entities isn't all the entities in the model? It's just the root context. The rest of the entities is inside Groups, Components and Image entities.
                                  http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/
                                    rvs1977
                                    In post number 7 in this thread there are two pieces of codes attached...
                                    The 1. piece of code draw boxes without observers, the 2. piece of code add observers to the boxes.
                                    When you have deleted a box, try to undo, and it attaches new observers in a way that it solves the problem with lost observers.
                                    It triggers when the red face is modified (push/pulled) using the def onElementModified(entities, entity) in the "MyEntitesObserver", and it messure the area of the green face.
                                    Get a Ruby
                                      Ok - seeing it now. Still trying to work out the code flow.
                                      But you still have the issue with setting observers adds to the Undo stack.
                                      So when you push pull - the observer triggers and add an event to the Undo stack. So when the user press undo after push/pull he first undo the attribute change - then he has to undo again to undo the push pull.
                                      If the user undo just one - he will have undone the attribute change, but not the push-pull - making your data invalid. Also, the user is likely to become frustrated that Undo is working unpredictably.
                                        Worked out why your observer triggered only once:
                                        The set_attribute call short-circuited the other events. When I commented out set_attribute and also changed the UI::Messagebox to this:
                                        puts "#{self} - Height changed - green face - area before: " + attr_area.to_s + " m² - area after: " + yv_area_new.to_s + " m²"
                                        You will then see that all the MyEntitiesObserver.new adds new observers - and doesn't remove the old ones. You'll see it output events for each instance you created. It was just your model change that prevented the events to propagate.
                                        <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model&nbsp;</span><span class="syntaxcomment">#&nbsp;Open&nbsp;model<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">ent&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxcomment">#&nbsp;All&nbsp;entities&nbsp;in&nbsp;model<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxcomment">#&nbsp;Current&nbsp;selection<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">MyModelObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ModelObserver<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onTransactionUndo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#UI.messagebox("onTransactionUndo;&nbsp;"&nbsp;+&nbsp;model.to_s)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#MyModelObserver<br />&nbsp;&nbsp;&nbsp;&nbsp;#Adding&nbsp;ModelObserver&nbsp;-&nbsp;Undo<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyModelObserver</span><span class="syntaxkeyword">.new)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;class&nbsp;</span><span class="syntaxdefault">MyEntityObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EntityObserver&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#def&nbsp;onEraseEntity(entity)&nbsp;#this&nbsp;work&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#UI.messagebox("onEraseEntity;&nbsp;"&nbsp;+&nbsp;entity.to_s)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#def&nbsp;onChangeEntity(entity)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#UI.messagebox("onChangeEntity;&nbsp;"&nbsp;+&nbsp;entity.to_s)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#class<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">MyEntitiesObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EntitiesObserver&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onElementModified</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_length&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_length"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_height&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_height"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_length&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_area&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;yv_area_new&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#UI.messagebox&nbsp;"Length&nbsp;changed&nbsp;-&nbsp;area&nbsp;before;&nbsp;"&nbsp;+&nbsp;attr_area.to_s&nbsp;+&nbsp;"&nbsp;m²&nbsp;-&nbsp;area&nbsp;after;&nbsp;"&nbsp;+&nbsp;yv_area_new.to_s&nbsp;+&nbsp;"&nbsp;m²"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#i.set_attribute&nbsp;"rsdict",&nbsp;"yv_face_area",&nbsp;yv_area_new<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#each&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#if&nbsp;attr_length<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_height&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_area&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;yv_area_new&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">"#{self}&nbsp;-&nbsp;Height&nbsp;changed&nbsp;-&nbsp;green&nbsp;face&nbsp;-&nbsp;area&nbsp;before;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">attr_area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxstring">"&nbsp;m²&nbsp;-&nbsp;area&nbsp;after;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">yv_area_new</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxstring">"&nbsp;m²"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#i.set_attribute&nbsp;"rsdict",&nbsp;"yv_face_area",&nbsp;yv_area_new<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#each&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#if&nbsp;attr_height<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#onElementModified_end&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#class<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">i&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">i&nbsp;</span><span class="syntaxkeyword">+=&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox&nbsp;</span><span class="syntaxstring">"number&nbsp;of&nbsp;boxes;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br /></span>
                                          rvs1977
                                          I'm not sure how to do these tests.
                                          Are you saying if I pushpull one red face, it triggers events for every instance?? (If there is 200 boxes it triggers 200 times?) (box=instance)
                                          Or will it trigger the number of times, you have runned the script which adds observers? (instance = observer added)
                                          (Because in my case it only shows the UI.messagebox once)
                                          Get a Ruby
                                            As describe above - in your case it triggers only once because when you modify the model with set_attribute it blocks all the other observers attached. Comment out the set_attribute code and you'll see all the observers you added will trigger.
                                            And then it's the issue with the Undo stack which I also mentioned.
                                            • 1 / 2
