    EntitiesObserver and Attributes - work around
    21 Posts 3 Posters 3.1k Views 3 Watching
      rvs1977
      Think I found a usable solution to this problem:
      (It only works in SU8+)
      1. Add EntitiesObserver to each Entity with the attributes("rsdict","area")
      2. Keep the EntitiesObservers when undoing a deleted group
      3. Keep the EntitiesObservers when copying a group.
      4. Add EntitiesOberservers to each group with the attributes ("rsdict", "area")
      The solution seems to be simple: - Every time something happens (like undo or change, etc.) the executed observer iterates through each entity and, in my case, when it finds an entity with the attributes ("rsdict", "area") it simply add_observer(MyEntitiesObserver.new).
      It can be testet with the two pieces of codes below.
      In this example it messures the area of the green face, when you pushpull the red face at the top.
      In the first codepiece it draws some boxes and adds some attributes, but dont add any observers. Try to run the code a few times so it will produce a number of boxes.
      mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      pts = []
      pts[0] = [ 0, 0, 0]
      pts[1] = [ 1000.mm, 0, 0]
      pts[2] = [ 1000.mm, 1000.mm, 0]
      pts[3] = [ 0, 1000.mm, 0]
      pts[4] = [ 0, 0, 1000.mm]
      pts[5] = [ 1000.mm, 0, 1000.mm]
      pts[6] = [ 1000.mm, 1000.mm, 1000.mm]
      pts[7] = [ 0, 1000.mm, 1000.mm]
      10.times do |i|
          rsgroup = ent.add_group
          rsgroup.entities.add_face pts[0..3]
          yv_face_height = rsgroup.entities.add_face pts[4..7]
          rsgroup.entities.add_face pts[0], pts[3], pts[7], pts[4]
          rsgroup.entities.add_face pts[3], pts[2], pts[6], pts[7]
          yv_face_length = rsgroup.entities.add_face pts[1], pts[2], pts[6], pts[5]
          yv_face_area = rsgroup.entities.add_face pts[0], pts[1], pts[5], pts[4]
          yv_face_height.pushpull rand(1000.mm)
          yv_area = yv_face_area.area.to_m.to_m
          yv_face_area.material = (0xAADEAA) #green
          yv_face_height.material =(0x8811FF) #red
          rsgroup.set_attribute "rsdict","area", yv_area
          yv_face_area.set_attribute "rsdict", "yv_face_area", yv_area
          yv_face_length.set_attribute "rsdict", "yv_face_length" , 0
          yv_face_height.set_attribute "rsdict", "yv_face_height", 0
          point = Geom;;Point3d.new (1100.mm * i, 0, 0)
          t = Geom;;Transformation.new point
          rsgroup.transform! t
      end #times_do
      ent.each do |o|
          point = Geom;;Point3d.new (0, 1100.mm, 0)
          o.transform! t
      end #each_do
      Second piece of code: - Here it add the observers. Every time the code is executed it will asign the observers. And it seems like it doesnt matter how many times you do it.There will only be one observer for each entity.
      class MyModelObserver < Sketchup;;ModelObserver
          def onTransactionUndo(model)
              #UI.messagebox("onTransactionUndo; " + model.to_s)
              Sketchup.active_model.entities.each do |o|
                  attr = o.get_attribute "rsdict","area"
                  if attr
                      o.add_observer(MyEntityObserver.new)
                      o.entities.add_observer(MyEntitiesObserver.new)
      end #MyModelObserver
      #Adding ModelObserver - Undo
      Sketchup.active_model.add_observer(MyModelObserver.new)
      class MyEntityObserver < Sketchup;;EntityObserver
          #def onEraseEntity(entity) #this work
              #UI.messagebox("onEraseEntity; " + entity.to_s)
          #end
          #def onChangeEntity(entity)
              #UI.messagebox("onChangeEntity; " + entity.to_s)
          #end
      end #class
      class MyEntitiesObserver < Sketchup;;EntitiesObserver
          def onElementModified(entities, entity)
              attr_length = entity.get_attribute "rsdict", "yv_face_length"
              attr_height = entity.get_attribute "rsdict", "yv_face_height"
      		if attr_length
                  entities.each do |i|
                      attr_area = i.get_attribute "rsdict", "yv_face_area"
                      if attr_area
                          yv_area_new = i.area.to_m.to_m
                          #UI.messagebox "Length changed - area before; " + attr_area.to_s + " m² - area after; " + yv_area_new.to_s + " m²"
                          i.set_attribute "rsdict", "yv_face_area", yv_area_new
                      end #attr_area
                  end #each do
              end #if attr_length
              if attr_height
                      if attr_area
                          UI.messagebox "Height changed - green face - area before; " + attr_area.to_s + " m² - area after; " + yv_area_new.to_s + " m²"
                      end #attr_area
                  end #each do
              end #if attr_height
          end #onElementModified_end
      end #class
      i = 0
      ent.each do |o|
          if attr
              i += 1
      UI.messagebox "number of boxes; " + i.to_s
      Get a Ruby
        There is still the problem that you modify the model on observer events. When you do that you interfer with any operation that is going on - which might be in the middle of a start/commit operation of another plugin or native tool. You'll be adding to the Undo stack - causing unexpected behaviour when the user expects to undo their last operation but instead the undo is your injected attribute change.
        Model change at observer events may cause bug splats.
          rvs1977
          Im not sure how to do it yet, but I think a solution could be to remove the observers, when editing the group, and adding the observer again when finished.
          It seems to be very quick to add observers to ALL the entities in the model, and its not possible to add more than one observer to each entity, so you dont have to take care if the entity allready has got one.
          Get a Ruby
            Strongly recommend you use observers sparsely. Also what you do within the events. Some events trigger many times a second - and that mean you can easily bog down SketchUp.
            Yes you can add more than one observer.
              rvs1977
              What I meant was, if you do like this:
              (adding 3 identical observers to one entity)
              Code:
              mygroup.entities.add_observer(myEntitiesObserver.new)
              it will only have one myEntitesObserver attached to mygroup. - not three. That means its easier to handle... You dont need to check if its allready added, its faster just to add new one to every entities.
              Yes you can add more observers to one entity eg. MyEntitiesObserverWatchFaces and MyEntitiesObserverWatchEdges
              Get a Ruby
                Not correct. For each new instance of your observer class you attach you add an observer:
                Here I first drew one line. Then added another observer. When I draw a second line I get two observer triggering - and they are both of the same class.
                However, if you attach the same instance of your observer to the same element, then it's no extra observers added:
                Here I only ever get one observer triggering - because I'd only ever attached a single instance.
                I store the reference to the observers I use. Then I remove it - just to be sure.
                ` @entities_observer = myEntitiesObserver.new
                def self.observers
                mygroup.entities.remove_observer( @entities_observer )
                mygroup.entities.add_observer( @entities_observer )
                end`
                Just to be sure
                  rvs1977
                  Ok, maybe you are right, but to me it seems like it only triggers once, even though I have attached it many times in a row.
                  Could it be that it is overwritten each time its attached?! As far as I can see its not possible to see which observers is added in the model.
                  If you try the code I have attached above you can what I mean...
                  (Run the first code a couple of times to get some boxes without observers, then run the second code as many times you want, and the observers only triggers once)
                  Get a Ruby
                    If you attach the same instance. But if you do like in my second example, you keep a reference to an instance and use that reference when you attach observers it won't create duplicates.
                    Correct, there isn't.
                      Got a sample model with "Boxes"?
                      What do you do to trigger the events?
                      Btw - you know that model.entities isn't all the entities in the model? It's just the root context. The rest of the entities is inside Groups, Components and Image entities.
                      http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/
                        rvs1977
                        In post number 7 in this thread there are two pieces of codes attached...
                        The 1. piece of code draw boxes without observers, the 2. piece of code add observers to the boxes.
                        When you have deleted a box, try to undo, and it attaches new observers in a way that it solves the problem with lost observers.
                        It triggers when the red face is modified (push/pulled) using the def onElementModified(entities, entity) in the "MyEntitesObserver", and it messure the area of the green face.
                        Get a Ruby
                          Ok - seeing it now. Still trying to work out the code flow.
                          But you still have the issue with setting observers adds to the Undo stack.
                          So when you push pull - the observer triggers and add an event to the Undo stack. So when the user press undo after push/pull he first undo the attribute change - then he has to undo again to undo the push pull.
                          If the user undo just one - he will have undone the attribute change, but not the push-pull - making your data invalid. Also, the user is likely to become frustrated that Undo is working unpredictably.
                            Worked out why your observer triggered only once:
                            The set_attribute call short-circuited the other events. When I commented out set_attribute and also changed the UI::Messagebox to this:
                            puts "#{self} - Height changed - green face - area before: " + attr_area.to_s + " m² - area after: " + yv_area_new.to_s + " m²"
                            You will then see that all the MyEntitiesObserver.new adds new observers - and doesn't remove the old ones. You'll see it output events for each instance you created. It was just your model change that prevented the events to propagate.
                            <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model&nbsp;</span><span class="syntaxcomment">#&nbsp;Open&nbsp;model<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">ent&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxcomment">#&nbsp;All&nbsp;entities&nbsp;in&nbsp;model<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxcomment">#&nbsp;Current&nbsp;selection<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">MyModelObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ModelObserver<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onTransactionUndo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#UI.messagebox("onTransactionUndo;&nbsp;"&nbsp;+&nbsp;model.to_s)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#MyModelObserver<br />&nbsp;&nbsp;&nbsp;&nbsp;#Adding&nbsp;ModelObserver&nbsp;-&nbsp;Undo<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyModelObserver</span><span class="syntaxkeyword">.new)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;class&nbsp;</span><span class="syntaxdefault">MyEntityObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EntityObserver&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#def&nbsp;onEraseEntity(entity)&nbsp;#this&nbsp;work&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#UI.messagebox("onEraseEntity;&nbsp;"&nbsp;+&nbsp;entity.to_s)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#def&nbsp;onChangeEntity(entity)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#UI.messagebox("onChangeEntity;&nbsp;"&nbsp;+&nbsp;entity.to_s)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#class<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">MyEntitiesObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EntitiesObserver&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onElementModified</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_length&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_length"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_height&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_height"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_length&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_area&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;yv_area_new&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#UI.messagebox&nbsp;"Length&nbsp;changed&nbsp;-&nbsp;area&nbsp;before;&nbsp;"&nbsp;+&nbsp;attr_area.to_s&nbsp;+&nbsp;"&nbsp;m²&nbsp;-&nbsp;area&nbsp;after;&nbsp;"&nbsp;+&nbsp;yv_area_new.to_s&nbsp;+&nbsp;"&nbsp;m²"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#i.set_attribute&nbsp;"rsdict",&nbsp;"yv_face_area",&nbsp;yv_area_new<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#each&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#if&nbsp;attr_length<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_height&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_area&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;yv_area_new&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">"#{self}&nbsp;-&nbsp;Height&nbsp;changed&nbsp;-&nbsp;green&nbsp;face&nbsp;-&nbsp;area&nbsp;before;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">attr_area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxstring">"&nbsp;m²&nbsp;-&nbsp;area&nbsp;after;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">yv_area_new</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxstring">"&nbsp;m²"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#i.set_attribute&nbsp;"rsdict",&nbsp;"yv_face_area",&nbsp;yv_area_new<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#each&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#if&nbsp;attr_height<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#onElementModified_end&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#class<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">i&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">i&nbsp;</span><span class="syntaxkeyword">+=&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox&nbsp;</span><span class="syntaxstring">"number&nbsp;of&nbsp;boxes;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br /></span>
                              rvs1977
                              I'm not sure how to do these tests.
                              Are you saying if I pushpull one red face, it triggers events for every instance?? (If there is 200 boxes it triggers 200 times?) (box=instance)
                              Or will it trigger the number of times, you have runned the script which adds observers? (instance = observer added)
                              (Because in my case it only shows the UI.messagebox once)
                              Get a Ruby
                                As describe above - in your case it triggers only once because when you modify the model with set_attribute it blocks all the other observers attached. Comment out the set_attribute code and you'll see all the observers you added will trigger.
                                And then it's the issue with the Undo stack which I also mentioned.
                                  rvs1977
                                  Ok. hopefully there is a solution. If I find one I will return...
                                  Get a Ruby
