    EntitiesObserver and Attributes - work around
    21 Posts 3 Posters 4.0k Views 3 Watching
      rvs1977
      @thomthom said:
      There is still the problem that you modify the model on observer events. When you do that you interfer with any operation that is going on - which might be in the middle of a start/commit operation of another plugin or native tool. You'll be adding to the Undo stack - causing unexpected behaviour when the user expects to undo their last operation but instead the undo is your injected attribute change.
      Model change at observer events may cause bug splats.
      Im not sure how to do it yet, but I think a solution could be to remove the observers, when editing the group, and adding the observer again when finished.
      It seems to be very quick to add observers to ALL the entities in the model, and its not possible to add more than one observer to each entity, so you dont have to take care if the entity allready has got one.
      Get a Ruby
        Strongly recommend you use observers sparsely. Also what you do within the events. Some events trigger many times a second - and that mean you can easily bog down SketchUp.
        Yes you can add more than one observer.
          rvs1977
          What I meant was, if you do like this:
          (adding 3 identical observers to one entity)
          Code:
          mygroup.entities.add_observer(myEntitiesObserver.new)
          it will only have one myEntitesObserver attached to mygroup. - not three. That means its easier to handle... You dont need to check if its allready added, its faster just to add new one to every entities.
          Yes you can add more observers to one entity eg. MyEntitiesObserverWatchFaces and MyEntitiesObserverWatchEdges
          Get a Ruby
            Not correct. For each new instance of your observer class you attach you add an observer:
            Here I first drew one line. Then added another observer. When I draw a second line I get two observer triggering - and they are both of the same class.
            However, if you attach the same instance of your observer to the same element, then it's no extra observers added:
            Here I only ever get one observer triggering - because I'd only ever attached a single instance.
            I store the reference to the observers I use. Then I remove it - just to be sure.
            ` @entities_observer = myEntitiesObserver.new
            def self.observers
            mygroup.entities.remove_observer( @entities_observer )
            mygroup.entities.add_observer( @entities_observer )
            end`
            Just to be sure
              rvs1977
              Ok, maybe you are right, but to me it seems like it only triggers once, even though I have attached it many times in a row.
              Could it be that it is overwritten each time its attached?! As far as I can see its not possible to see which observers is added in the model.
              If you try the code I have attached above you can what I mean...
              (Run the first code a couple of times to get some boxes without observers, then run the second code as many times you want, and the observers only triggers once)
              Get a Ruby
                If you attach the same instance. But if you do like in my second example, you keep a reference to an instance and use that reference when you attach observers it won't create duplicates.
                Correct, there isn't.
                  Got a sample model with "Boxes"?
                  What do you do to trigger the events?
                  Btw - you know that model.entities isn't all the entities in the model? It's just the root context. The rest of the entities is inside Groups, Components and Image entities.
                  http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/
                    rvs1977
                    In post number 7 in this thread there are two pieces of codes attached...
                    The 1. piece of code draw boxes without observers, the 2. piece of code add observers to the boxes.
                    When you have deleted a box, try to undo, and it attaches new observers in a way that it solves the problem with lost observers.
                    It triggers when the red face is modified (push/pulled) using the def onElementModified(entities, entity) in the "MyEntitesObserver", and it messure the area of the green face.
                    Get a Ruby
                      Ok - seeing it now. Still trying to work out the code flow.
                      But you still have the issue with setting observers adds to the Undo stack.
                      So when you push pull - the observer triggers and add an event to the Undo stack. So when the user press undo after push/pull he first undo the attribute change - then he has to undo again to undo the push pull.
                      If the user undo just one - he will have undone the attribute change, but not the push-pull - making your data invalid. Also, the user is likely to become frustrated that Undo is working unpredictably.
                        Worked out why your observer triggered only once:
                        The set_attribute call short-circuited the other events. When I commented out set_attribute and also changed the UI::Messagebox to this:
                        puts "#{self} - Height changed - green face - area before: " + attr_area.to_s + " m² - area after: " + yv_area_new.to_s + " m²"
                        You will then see that all the MyEntitiesObserver.new adds new observers - and doesn't remove the old ones. You'll see it output events for each instance you created. It was just your model change that prevented the events to propagate.
                        <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model&nbsp;</span><span class="syntaxcomment">#&nbsp;Open&nbsp;model<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">ent&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxcomment">#&nbsp;All&nbsp;entities&nbsp;in&nbsp;model<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxcomment">#&nbsp;Current&nbsp;selection<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">MyModelObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ModelObserver<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onTransactionUndo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#UI.messagebox("onTransactionUndo;&nbsp;"&nbsp;+&nbsp;model.to_s)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#MyModelObserver<br />&nbsp;&nbsp;&nbsp;&nbsp;#Adding&nbsp;ModelObserver&nbsp;-&nbsp;Undo<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyModelObserver</span><span class="syntaxkeyword">.new)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;class&nbsp;</span><span class="syntaxdefault">MyEntityObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EntityObserver&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#def&nbsp;onEraseEntity(entity)&nbsp;#this&nbsp;work&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#UI.messagebox("onEraseEntity;&nbsp;"&nbsp;+&nbsp;entity.to_s)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#def&nbsp;onChangeEntity(entity)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#UI.messagebox("onChangeEntity;&nbsp;"&nbsp;+&nbsp;entity.to_s)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#class<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">MyEntitiesObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EntitiesObserver&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onElementModified</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_length&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_length"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_height&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_height"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_length&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_area&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;yv_area_new&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#UI.messagebox&nbsp;"Length&nbsp;changed&nbsp;-&nbsp;area&nbsp;before;&nbsp;"&nbsp;+&nbsp;attr_area.to_s&nbsp;+&nbsp;"&nbsp;m²&nbsp;-&nbsp;area&nbsp;after;&nbsp;"&nbsp;+&nbsp;yv_area_new.to_s&nbsp;+&nbsp;"&nbsp;m²"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#i.set_attribute&nbsp;"rsdict",&nbsp;"yv_face_area",&nbsp;yv_area_new<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#each&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#if&nbsp;attr_length<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_height&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr_area&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"yv_face_area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;yv_area_new&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">"#{self}&nbsp;-&nbsp;Height&nbsp;changed&nbsp;-&nbsp;green&nbsp;face&nbsp;-&nbsp;area&nbsp;before;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">attr_area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxstring">"&nbsp;m²&nbsp;-&nbsp;area&nbsp;after;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">yv_area_new</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxstring">"&nbsp;m²"&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#i.set_attribute&nbsp;"rsdict",&nbsp;"yv_face_area",&nbsp;yv_area_new<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#attr_area<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#each&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#if&nbsp;attr_height<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#onElementModified_end&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#class<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">i&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">attr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">attr&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">i&nbsp;</span><span class="syntaxkeyword">+=&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox&nbsp;</span><span class="syntaxstring">"number&nbsp;of&nbsp;boxes;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br /></span>
                          rvs1977
                          I'm not sure how to do these tests.
                          Are you saying if I pushpull one red face, it triggers events for every instance?? (If there is 200 boxes it triggers 200 times?) (box=instance)
                          Or will it trigger the number of times, you have runned the script which adds observers? (instance = observer added)
                          (Because in my case it only shows the UI.messagebox once)
                          Get a Ruby
                            As describe above - in your case it triggers only once because when you modify the model with set_attribute it blocks all the other observers attached. Comment out the set_attribute code and you'll see all the observers you added will trigger.
                            And then it's the issue with the Undo stack which I also mentioned.
                              rvs1977
                              Ok. hopefully there is a solution. If I find one I will return...
                              Get a Ruby
