    Intersect_with problems
    3 Posts 3 Posters 958 Views 3 Watching
      timwarner
      I've been using intersect_with to find the intersection of a cylinder (a group) and a prism (another group), where the prism is skewed relative to the prism. In some, but not all, instances the method drops an edge. Here's a pic:
      The intersection breaks when you try it manually as well -- easy to fix, but rather undermines the idea of a plug-in! I'm attaching an abbreviated model.
      Any ideas??
      Intersect problem.skp
        I confirm the weirdness.
        At first I thought that perhaps the dims were too small - but they are not [~43mm] !
        Or the axes were messed up - they are not!
        That one face refuses to intersect 'with the model' unless you move it [slightly]...
        It's plain weird πŸ˜•
        • sdmitchS Offline
          sdmitch
          Weird indeed but moving the prism up 1mm solves the problem.
          http://sdmitch.blogspot.com/
