    [REQ] Random Profiles
    12 Posts 2 Posters 640 Views 2 Watching
      If not yet existing
      Drawn in Y, in first time without constaint in Y so just "raws"
      In second time (if courageaous) with same constaint than in X so columns + raws
      Here the possibilities drawn in X
      • sdmitchS Offline
        sdmitch
        If not yet existing
        [attachment=0:2m70jbmg]<!-- ia0 -->Random_profiles.jpg<!-- ia0 -->[/attachment:2m70jbmg]
        Your example profiles don't appear to be very "random". "raws"? Perhaps you mean "rows".
        The following code will generate a 10 X 10 X 10 random set of profiles.
        for y in 0..10
         p=[]
         for x in 0..10
          p<<Geom;;Point3d.new(x,y,rand(10))
         for i in 1..10
          ent.add_line(p[i-1],p[i])
        http://sdmitch.blogspot.com/
          Yes Row πŸ˜„
          And yes not very randomly : just 45Β°, -45Β°, 0Β° and yes or not 90Β° permit from the start
          For have curves like section's rivers, quiet valley πŸ˜„ ...
            Hum
            I have indroduced your code in the Webconsole by Jim Foltz
            but seems nothing is made πŸ˜‰
            Just an
            (eval):7:in β€˜initialize’: undefined local variable or method β€˜ent’ for #WebConsole:0x1d8be9d8
            I have tried to use Ruby language in the past but it's not a language fluent for me alas! 😳
            • sdmitchS Offline
              sdmitch
              I use Web Console also but I didn't include the first three lines where mod, ent, and sel are defined. Try this
              mod = Sketchup.active_model
              ent = mod.entities
              sel = mod.selection
              for y in 0..10
               p=[];z=5
               for x in 0..10
                case rand(3)
                 when 0; z -= 1 if z > 0
                 when 2; z += 1 if z < 10
                p<<Geom;;Point3d.new(x,y,z)
               for i in 1..10
                Sure better πŸ˜‰
                Problem : Start and End must be the same πŸ˜‰
                Or better between each Start (on the Y) just the 3 possibilities 45Β°, -45Β°, 0Β°, (or 90Β° if enable)
                Same for the Ends(on the Y)
                Same for each segment(on the Y)
                • sdmitchS Offline
                  sdmitch
                  Added statement to make start=end
                  ent = mod.entities
                  sel = mod.selection
                  for y in 0..10
                   p=[];z=5
                   for x in 0..10
                    case rand(3)
                    z = 5 if x==10#<<< to make start=end
                   for i in 1..10
                    Cool πŸ˜„ but as I said in last post
                    that will great if from the first profile
                    Next Start, next vertex, next End on Y will take the 3 possibilities πŸ˜„
                    for more smoothing forms
                    Here I have just take the first profile and rotate by 90Β° so too symmetric
                    • sdmitchS Offline
                      sdmitch
                      Code added to vary start/end z
                      ent = mod.entities
                      sel = mod.selection
                      start_z=5
                      for y in 0..10
                       p=[];z=start_z
                       for x in 0..10
                        case rand(3)
                        z = start_z if x==10
                       for i in 1..10
                        case rand(3)
                         when 0; start_z -= 1 if start_z > 0
                         when 2; start_z += 1 if start_z < 10
                        This can't be exist on Y: too big πŸ˜‰
                        In fact the first profile gives a curve
                        then second will be made on the Y from this first result from each vertex
                        then third from the second etc...
                          Perfect! πŸ‘
                          and if the first random profile don't please just relaunch the script! β˜€
                          Bravo! 😎
                          • sdmitchS Offline
                            sdmitch
                            So each point on subsequent profiles should be determined like the starting Z.
                            ent = mod.entities
                            sel = mod.selection
                             p=[];z=5;y=0
                             for x in 0..10
                              case rand(3)
                              z=5 if x==9
                            for y in 1..10
                             for i in 1..10
                             for i in 0..10
                              p[i].y=y
                              case rand(3)
                               when 0; p[i].z -= 1 if p[i].z > 0
                               when 2; p[i].z += 1 if p[i].z < 10
                             p[10].z=p[0].z
