    .edges returns a face
    9 Posts 5 Posters 578 Views 5 Watching
      timwarner
      I can't figure this one out. Here's the output from the Ruby Console:
      back
      #Sketchup::Face:0x1cbbfe74
      back.edges.each{|e| puts e}
      #Sketchup::Edge:0x1cbc1850
      #Sketchup::Edge:0x1cbc1a1c
      #Sketchup::Face:0x1cbcfc84
      #Sketchup::Edge:0x1cbc0cc0
      [#Sketchup::Edge:0x1cbc1850, #Sketchup::Edge:0x1cbc1a1c, #Sketchup::Face:0x1cbcfc84, #Sketchup::Edge:0x1cbc0cc0]
      How can the .edges method return a Face?
        BUT
        face.edges doesn't return a face, it does return an array of edges.
        face=Sketchup.active_model.selection[0] #<Sketchup::Face:0xef75e64> face.edges [#<Sketchup::Edge:0xf0a8b10>, #<Sketchup::Edge:0xef75e78>, #<Sketchup::Edge:0xf0a8c28>]
        or
        face.edges.each{|e|puts e} #<Sketchup::Edge:0xf0a8b10> #<Sketchup::Edge:0xef75e78> #<Sketchup::Edge:0xf0a8c28> [#<Sketchup::Edge:0xf0a8b10>, #<Sketchup::Edge:0xef75e78>, #<Sketchup::Edge:0xf0a8c28>]
        Are you using the standard Ruby Console ?
        Do you have any other tools that might ill-advisedly mess with the base-classes like Sketchup::Face ?
        Your installation is most likely 'broken' πŸ˜•
        Have you considered reinstalling ?
          timwarner
          @tig said:
          BUT
          or
          Yes, it's the standard Ruby Console.
          No, I have no other tools that mess with the base-class.
          I'll re-install and see what happens.
          Thx for the feedback.
            Jim
            I'd be interested in seeing the model (or portion of) to see if it can be reproduced.
            • Dan RathbunD Offline
              Dan Rathbun
              Tim, are you really still using SketchUp 8.0.4810 ??
              I'm not here much anymore.
                timwarner
                I reinstalled SU and the problem went away, so it looks like TIG was correct. I'll have to check my backups to see what version of SU was running (it would have been current, though). The profile info was obsolete.
                • K Offline
                  kwalkerman
                  I did see something like that once before - I had a plugin that traced faces and did something like:
                  face.edges.each do |e|
                  do something with an edge
                  ... and every once in 10,000 faces, I'd see something like you're describing, although I could never reproduce it on command. This was with SU 7.0. I never found a fix - just found another way to execute the plugin.
                    Dan Rathbun
                    Likely:
                      next unless e.is_a?(Sketchup;;Edge)
                      # do something with an edge
                    • K Offline
                      kwalkerman
                      Dan - the bug came immediately after:
                      if e.is_a? Sketchup::Edge
                      ... it was very strange, and as I said, happened once in a great while - I couldn't figure out how to make it happen on command.
