    Make all sections active
    1 Posts 1 Posters 167 Views 1 Watching
    • P
      penumbra
      Often times while modeling I use section cuts to conceal parts of components, particularly on models with extensive repetition of the same component like on a facade, for instance. The problem is that active sections are saved as part of a scene, when you have several of these section cuts some may become inactive as I work trough the model. The questions is this: is there a plugin or process to make all sections in a scene active, and moreover, can such script drill down to groups or components that may be modified by section cuts?
