    Flattening wire frames
    3 Posts 2 Posters 231 Views 2 Watching
      Rcbuilder
      I'm having issues with creating flat surfaces that can be push/pulled to thickness. I won't go into the complications of it but is there a way to take a wire frame and drop it onto a plane in order to flatten it out and make a surface?
      RCB
        The basic, native tool for this would be Drape of the Sandbox tools. If you have not ectivated the Sandbox tools yet, go to Window > Preferences > Extensions and check its box there - restart SU and if the toolbar is not active yet, activate it under View > Toolbars.
        Drape will always drape a linework along the blue axis so you need to place a big enough face (a rectangle) below the linework and use the drape tool this way. Best is to group your linework first.
          Rcbuilder
          Thanks Gaieus
          I will try that.
