    Nudge amount
    layout
    5 Posts 2 Posters 926 Views 2 Watching
    • A
      ArCAD-UK
      Does anyone know if you can adjust the "nudge" amount in LO, it seems to be fixed at 1mm?
      • RichardR
        Richard
        No mate it can't be adjusted (shame) - BTW it's set at 0.5mm! You can always scale up the page content then scale it back later to suit, or change the grid interval and use snap to grid!
        BUILTBRAND.COM.AU
        • A
          ArCAD-UK
          Thanks for the confirmation Rich. It would be nice if it followed the fine grid setting for the jump amount - One for the wishlist. My problem was the drawing wasn't aligned to the grid and I was trying to move a line about 0.25mm to show a dash-dot line between two solids. Anyway job done.
          • RichardR
            Richard
            Yeah matching grid / nudge would be cool!
            Mate remember you can move an object an exact amount. Draw the line over the object edge, select and move parallel to any distance and then type in 0.25mm and hit enter. Works the same as sketchup in this regards.
            BUILTBRAND.COM.AU
            • A
              ArCAD-UK
              Duh 😳 πŸ‘
