    Import pdf
    layout
    7 Posts 4 Posters 3.9k Views 4 Watching
    • Z
      Zacchia
      Is there a way to import another pdf to layout??
      • bmikeB
        bmike
        @zacchia said:
        yes. just like a SketchUp file or PNG / JPG image.
        mike beganyi design + consulting llc
        • EarthMoverE
          EarthMover
          I could be wrong, but I believe .pdf import is only for Mac. I don't see the option on windows.
          Content Creator at Skapeup
          • J
            JuanV.Soler
            lucky you bmike
            that is not possible in windows
            • bmikeB
              bmike
              @juanv.soler said:
              lucky you bmike
              ahhh. i thought it was only in SketchUp. Pity that LO is crippled too.
              I wonder, does a PDF inserted in LO on a Mac lose its functionality if you were to open it on a PC?
              -Mike
              • Z
                Zacchia
                Thanks for answer!
                • Z
                  Zacchia
                  Now I have found a way to use SU Layout also for other documents having pdf's:
                  I have a pdf with paper size and scale as needed. Then save this image as a png file (with a high dpi resolution like 300). Then make the white color (for example the paperbackground) transparent. Then import this png in SU Layout, paper size must be same as the original pdf. Then scale the png in the upper left and under right corner. That'it, now the size is like importing a pdf.
                  Maybe ohters can use this too...
