    Rotating handle then opening door
    6 Posts 2 Posters 879 Views 2 Watching
    • I Offline
      imadamjad
      Hello,
      I am pretty much a noob at DCs, I was wondering how you would rotate a door handle, say 45 degrees and THEN have the door open 90 degrees. I have my door setup with handle rotating but i need to door and handle to rotate as if you are opening it realistically. Hopefully not too difficult to do.
      door.skp
        Jim
        In SketchUp Components, search for "non concurrent" for my example.
        (http://sketchup.google.com/3dwarehouse/details?mid=671022c8c47d24e4a4eae8e0d18c3e5e)
        • I Offline
          imadamjad
          Thank You for your reply however how do you get your model to work/animate.
            Jim
            [flash=853,480:14ll6i7v]http://www.youtube.com/v/kNme_x4odvU&hd=1&fs=1[/flash:14ll6i7v]
            • I Offline
              imadamjad
              Thank You, it now works, the only thing I did differently was download it from 3d warehouse from a browser not directly inside sketchup, that is why it was not dynamically interactive.
              Again thanks for the help.
                Jim
                Right, this model was intended to be imported into a model. If the model was downloaded, use File > Import to add the component to the model.
