    Number of processors
    4 Posts 3 Posters 404 Views 3 Watching
      maricanis
      Is there a way to get number of processors with Ruby in Sketchup.
      I've found on internet solutions like this
      require 'win32ole'
      wmi = WIN32OLE.connect("winmgmts;//")
      num = wmi.ExecQuery("select * from Win32_ComputerSystem").NumberOfProcessors
      problem is when I run this in Sketchup I get error
      - unknown property or method `NumberOfProcessors'
          HRESULT error code;0x80020006
            Unknown name.
      Error; #<WIN32OLERuntimeError; unknown property or method `NumberOfProcessors'
            Unknown name.>
      I'm using win32ole posted here: [Plugin Library] Win32API and Win32OLE so files
        Is this any help?
        # Returns the number of processor for Linux, OS X or Windows.
        def number_of_processors
          if RUBY_PLATFORM =~ /linux/
            return `cat /proc/cpuinfo | grep processor | wc -l`.to_i
          elsif RUBY_PLATFORM =~ /darwin/
            return `sysctl -n hw.logicalcpu`.to_i
          elsif RUBY_PLATFORM =~ /win32/
            # this works for windows 2000 or greater
            require 'win32ole'
            wmi.ExecQuery("select * from Win32_ComputerSystem").each do |system|
              begin
                processors = system.NumberOfLogicalProcessors
              rescue
                processors = 0
              return [system.NumberOfProcessors, processors].max
          raise "can't determine 'number_of_processors' for '#{RUBY_PLATFORM}'"
        • Dan RathbunD Offline
          Dan Rathbun
          On Windows, an environment var is set for the number of processors:
          num = ENV['NUMBER_OF_PROCESSORS'].to_i
          I'm not here much anymore.
            β˜€ num = ENV['NUMBER_OF_PROCESSORS'].to_i is much easier than the other way and should be fine unless you want to have a cross-platform solution... We don't know if MAC has the same ENV variable 0 - some references are similar to PC, while others can be the same ??
