    Hole in 3-d Wall as a Component?
    2 Posts 2 Posters 182 Views 2 Watching
    • H
      horton_brian
      I can use the Push/Pull tool (or the Create Hole On Solid Plug-in) to make a hole in a solid - like a window in a solid wall - but is there any way to make the hole itself into a component so it can be resized or moved? This works with standard window components from the library, but only for cutting a window through a 2-d surface, not through a 3-d wall as far as I can see.
      Brian
      • GaieusG
        Have a look at this plugin: http://forums.sketchucation.com/viewtopic.php?t=30846
