    Making a face
    3 Posts 2 Posters 309 Views 2 Watching
    • A
      Alucinor
      I'm trying to make a half circle and then pushpull it into a half cylinder.
      The way I went about it was making an arccurve and then putting a line at the base of this curve. However reading through the the api it seems like it isn't possible to make a face from a curve and an edge. Is this the case? If so, what would you recommend for making a half cylinder?
      Entities.add_faceSketchUp 6.0+
      The add_face method is used to create a face. You can call this method a number of ways:
          entities.add_face(edge1, edge2, edge3, ...)
          entities.add_face(edgearray)
          entities.add_face(pt1, pt2, pt3, ...)
          entities.add_face([pt1, pt2, pt3,...])
          entities.add_face(curve)
      For the last form that takes a Curve, the curve must be closed - like a circle.
      Arguments:
      some_entities
          Either a series of Edge or Point3d objects, an array of Point3d objects, or a closed Curve.
      Returns:
      face
          a Face object if successful
      depth = 100
      >      width = 100
      >      model = Sketchup.active_model
      >      entities = model.active_entities
      >      pts = []
      >      pts[0] = [0, 0, 0]
      >      pts[1] = [width, 0, 0]
      >      pts[2] = [width, depth, 0]
      >      pts[3] = [0, depth, 0]
      >      # Add the face to the entities in the model
      >      face = entities.add_face pts
      >      if (face)
      >        UI.messagebox face
      >      else
      >        UI.messagebox "Failure"
      >      end
      • TIGT
        Make the Arc.
        It returns an array of its Edges.
        edges=entities.add_arc(...)
        You then have several ways of adding a Face from those...
        For example make an array of the vertices and use those...
        verts=[] edges.each{|e|verts << e.vertices} verts.flatten.uniq!
        Then use
        entities.add_face(verts)
        There are also other ways, for example add the missing edge
        ed=entities.add_line(edges[0].curve.first_edge.start.position, edges[0].curve.last_edge.end.position) edges << ed
        Then use
        entities.add_face(edges)
        etc...
        • A
          Alucinor
          Thanks a bunch TIG, I forgot you could get the arcs edges! Still organizing all this information
