    Aconnolls WIP
    27 Posts 7 Posters 3.2k Views 7 Watching
      aconnoll
      Hi All,
      Sometime ago I introduced myself on here and have since been head down arse up πŸ˜„ Ive finally done something I feel I can actually post up without being too embarrassed haha. I feel like ive grasped a few modelling concepts and have been hugely inspired by many on here but also mostly by ixlrlxi/600v. His style is right up my alley and im sure from my WIP below you will clearly see the influence.
      Please note I have no idea on rendering and am only just starting to learn about rendering after devoting all my time to modelling techniques so go easy πŸ˜„ I will start trawlling the net on VRay rendering tutorials soon.
      Hope I can inspire someone one day as much as alot of you on here have done for me.
      Cheers,
      Adam
      http://aconnoll.deviantart.com/
        aconnoll
        Here is another vehicle ive been working on. Its some sort of complex mobile research facility?? Perhaps designed for harsh or semi-hostile environments.
        • CarlohC Offline
          Carloh
          very cool and very creative! would love to see some texturing.
          • Bryan KB Offline
            Cool designs! Love the semi-retro look.
              aconnoll
              Had some fun with lighting and am loving the toon effect on VRay. Only just starting to explore textures/materials. The light settings can be a real pain so I just deal with it by placing everything in a large box. Seems to do the trick if I dont want natural/sunlight type light.
              Any idea on what causes that "ripping" effect underneath the lights on the left hand side? The shadows dont look too bad but I cant seem to find any setting that corrects the strange tearing effect.
                aconnoll
                Currently working on a rat rod
                  aconnoll
                  Another update on the rat rod. Engine in, need to do gearbox, radiator but am going to leave it fairly simplistic as its going to be rendered in the toon/600v style.
                    aconnoll
                    Completed most of the front section now. Need to make a start on the body..
                      aconnoll
                      Rendered the rat rod in the toon/600v style. Comments welcome..
                      • iichiversiiI Offline
                        iichiversii
                        Iv being looking for a toon render for SU, what render engine are you using? Great model πŸ‘
                        Bring on the Rain...
                          aconnoll
                          Gday, yeah im using VRay plugin. It's not bad at giving a toon effect, in the couple of days ive been playing with it. I essentially wanted something that would just trace with a black line but it doesnt quite work like that. It does the job for me though, as ive modelled my way around its limitations that ive found.
                            aconnoll
                            Retro concept, please comment on improvements that could be made..
                              aconnoll
                              a render of the first car I did at the start
                                iichiversii
                                The wheel arches, I think it would be better to Make the front wheel arche flush with the wheels and the back arches to be more rounded like the front arches, ha does that make sense? Great model πŸ‘
                                  aconnoll
                                  haha I think so, the only reason I set the front wheels back so far into the arch is because the small cut out is just for design. The wheels need to turn and would foul on the arches if they were any closer. Think of the front arches like the rear of a BX Citroen πŸ˜„ Thanks for the suggestion though πŸ˜„
                                  Speaking of the toon render, ive found if you set the normal threshold from .01 to .99, you get more outlines on the circular patterns. I didnt do that in the red concept retro but will show you in some newer renders to come of various things. I want to attempt a toony looking ED-209. Whether or not I can pull it off is the question haha..
                                    aconnoll
                                    Fun in a forklift. 7.5hrs from first block to final render
                                      aconnoll
                                      Was watching Aliens and was inspired to create a med lab of sorts.
                                      • Bryan KB Offline
                                        Those look great! Love that forklift! πŸ˜†
                                          aconnoll
                                          Started out making ED 209, got bored and made a robot factory instead.
                                          • Bryan KB Offline
                                            Wow. Nice!
                                            • 1 / 2
