    RETRIEVE SCALE
    3 Posts 2 Posters 585 Views 2 Watching
      adebeo
      Hi all, sorry for my english (i'm french, and ever in french I'm making a lot of mistake, ...)
      Well,
      I'm looking to a simple way to get the scale of an componant instance.
      Hi try to use
      instance.transformation.to
      _a but I don't find description about the 16 values.
      The last 4 describe the origine of the instance, and the [0], [3], [7] other describe the scale until a rotation ?
      Best regards
      adebeo
      Nos Formations sketchup
      Notre blog : www .adebeo.com/wp/
      Nos tutoriels: www .youtube.com/adebeo
        Dig through this lot - I wrote it a while back... it makes several extra methods for [Tr: Fouillez dans ce lot - Je l'ai écrit tout à l'heure... il fait plusieurs méthodes supplémentaires pour] Geom::Transformation; e.g. [EX.] object.transformation.scaleX >>> 1.0
        class Geom;;Transformation
          def euler_angle(xyz=[])
               m = self.xaxis.to_a + self.yaxis.to_a + self.zaxis.to_a
               if m[6] != 1 and m[6]!= 1
                  ry = -Math.asin(m[6])
                  rx = Math.atan2(m[7]/Math.cos(ry),m[8]/Math.cos(ry))
                  rz = Math.atan2(m[3]/Math.cos(ry),m[0]/Math.cos(ry))
               else
                  rz = 0
                  phi = Math.atan2(m[1],m[2])
                  if m[6] == -1
                     ry = Math;;PI/2
                     rx = rz + phi
                  else
                     ry = -Math;;PI/2
                     rx = -rz + phi
               return -rx if xyz==0
               return -ry if xyz==1
               return -rz if xyz==2
               return [-rx,-ry,-rz] if xyz==[]
          def getX()
            self.to_a[12]
          def getY()
            self.to_a[13]
          def getZ()
            self.to_a[14]
          def setX(x)
            if not x.class==Float and not x.class==Integer
              puts "Transformation;;setX( ) expects a Float or Integer."
              return nil
            end#if
            x=x.to_f
            t=self.to_a
            t[12]=x
            return self.set!(t)
          def setY(y)
            if not y.class==Float and not y.class==Integer
              puts "Transformation;;setY( ) expects a Float or Integer."
              return nil
            end#if
            y=y.to_f
            t=self.to_a
            t[13]=y
            return self.set!(t)
          def setZ(z)
            if not z.class==Float and not z.class==Integer
              puts "Transformation;;setZ( ) expects a Float or Integer."
              return nil
            end#if
            z=z.to_f
            t=self.to_a
            t[14]=z
            return self.set!(t)
          def scaleX()
            Math.sqrt(self.to_a[0]**2+self.to_a[1]**2+self.to_a[2]**2)
          def scaleY()
            Math.sqrt(self.to_a[4]**2+self.to_a[5]**2+self.to_a[6]**2)
          def scaleZ()
            Math.sqrt(self.to_a[8]**2+self.to_a[9]**2+self.to_a[10]**2)
          def rotX()
             #(Math.atan2(self.to_a[9],self.to_a[10]))
             #Math.acos(self.to_a[5])
             euler_angle(0)
          def rotY()
            #(Math.arcsin(self.to_a[8]))
            #Math.acos(self.to_a[0])
            euler_angle(1)
          def rotZ()
            #(-Math.atan2(self.to_a[4],self.to_a[0]))
            #Math.asin(self.to_a[4])
            euler_angle(2)
          def rotXYZ()
            euler_angle()
          def rot_a() ### rotation matrix 4x3 3 and 7 are nil
            t=self.to_a
            r=[]
            [0,1,2,3,4,5,6,7,8,9,10].each{|i|r[i]=t[i]}
            r[3]=nil
            r[7]=nil
            return r
          def rotation_from_xyz(xyz)
            if not xyz.class==Array and not xyz[2] and not xyz[0].class==Float and not xyz[1].class==Float and not xyz[2].class==Float
              puts "Transformation;;rotation_from_xyz( ) expects a 3 Item Array of Angles [as Floats]."
              return nil
            end#if
            tx=Geom;;Transformation.rotation(self.origin,X_AXIS,xyz[0])
            ty=Geom;;Transformation.rotation(self.origin,Y_AXIS,xyz[1])
            tz=Geom;;Transformation.rotation(self.origin,Z_AXIS,xyz[2])
            t=(tx*ty*tz)
            return self.set!(t)
          def rotation_from_xyz_locally(xyz)
              puts "Transformation;;rotation_from_xyz_locally( ) expects a 3 Item Array of Angles [as Floats]."
              return nil
            end#if
            tx=Geom;;Transformation.rotation(self.origin,self.xaxis,xyz[0])
            ty=Geom;;Transformation.rotation(self.origin,self.yaxis,xyz[1])
            tz=Geom;;Transformation.rotation(self.origin,self.zaxis,xyz[2])
            t=(tx*ty*tz)
            return self.set!(t)
          def rotation_from_rot_a(rot_a)
            if not rot_a.class==Array and not rot_a[10]
              puts "Transformation;;rotation_from_rot_a( ) expects an 11 Item Array."
              return nil
            end#if
            t=self.to_a
            [0,1,2,4,5,6,8,9,10].each{|i|t[i]=rot_a[i].to_f}
            return self.set!(t)
          def rotation_from(trans)
            if not trans.class==Geom;;Transformation
              puts "Transformation;;rotation_from( ) expects a Sketchup;;Transformation."
              return nil
            end#if
            t=self.to_a
            tt=trans.to_a
            [0,1,2,4,5,6,8,9,10].each{|i|t[i]=tt[i].to_f}
            return self.set!(t)
          def origin_from(trans)
              puts "Transformation;;origin_from( ) expects a Sketchup;;Transformation."
              return nil
            end#if
            t=self.to_a
            tt=trans.to_a
            [12,13,14].each{|i|t[i]=tt[i].to_f}
            return self.set!(t)
            ### or plain old ### self.origin ### ?
        end#class
          adebeo
          Thanks !
          it's works and I use
            def scaleX()
            def scaleY()
            def scaleZ()
          adebeo
