    Exporting as MXS to Maxwell
    3 Posts 2 Posters 1.4k Views 2 Watching
      jrm1
      When I export as an MXS to use the model in Maxwell Studio, some objects are missing. One example is this: a group of 3 trees are in the model, but only one of them appears in Studio.
      Is there anything I should be checking in SU to avoid this? By the way, the 'missing' objects were visible, not hidden in SU.
      • jason_marantoJ Offline
        jason_maranto
        Most likely the objects are there -- they are just instances, which do not show by default in Maxwell Studio (however they should render).
        Turn off "use instances" and that should clear up the issue... you can also tweak the settings in Studio to show instances if you care to get a bit more in-depth with the software.
        Best,
        Jason.
          jrm1
          Thanks Jason, I'll try that.
