    [Plugin] Textures exporter plugin (free)
    5 Posts 2 Posters 6.0k Views 2 Watching
    • IneshtineI Offline
      Ineshtine
      I have written a plugin to export all of the textures from your models. It's very fast and not coded in Ruby. It's freeware and you can get it from http://Raylectron.com
      Please let me know how it work for you?
      What? you haven't tried Raylectron yet?
        chad3006
        It works fine, but I noticed a little glitch. After I've exported the textures once and then modify the model and try to re-export, the tool won't load a second time. After a re-boot of SU, it will work again. (SU8 and WinXP)
          Ineshtine
          I can't make it to do that! I've tried everything, even loading another model without exiting SU, and it comes up everytime! Maybe the window has moved behind the SU window?
            chad3006
            No, I just checked to make sure it wasn't hidden behind the SU screen. In fact I don't even have to do anything to the model, just try to re-open the plugin and it won't come up a second time.
            Edit: Just on a whim I decided to try a reboot of my whole computer (you know how some installs don't completely take until a system reboot.) That seems to have fixed the issue. I'm using XP pro if that makes any difference. Anyway -- SOLVED.
              Ineshtine
              wow! that is weird! but thanks to let me know how you fixed it. I wouldn't have though of a reboot to fix it!
