    [Plugin] Textures exporter plugin (free)
    5 Posts 2 Posters 6.2k Views 2 Watching
    • IneshtineI
      Ineshtine
      I have written a plugin to export all of the textures from your models. It's very fast and not coded in Ruby. It's freeware and you can get it from http://Raylectron.com
      Please let me know how it work for you?
      What? you haven't tried Raylectron yet?
      • C
        chad3006
        It works fine, but I noticed a little glitch. After I've exported the textures once and then modify the model and try to re-export, the tool won't load a second time. After a re-boot of SU, it will work again. (SU8 and WinXP)
        • IneshtineI
          Ineshtine
          I can't make it to do that! I've tried everything, even loading another model without exiting SU, and it comes up everytime! Maybe the window has moved behind the SU window?
          • C
            chad3006
            No, I just checked to make sure it wasn't hidden behind the SU screen. In fact I don't even have to do anything to the model, just try to re-open the plugin and it won't come up a second time.
            Edit: Just on a whim I decided to try a reboot of my whole computer (you know how some installs don't completely take until a system reboot.) That seems to have fixed the issue. I'm using XP pro if that makes any difference. Anyway -- SOLVED.
            • IneshtineI
              Ineshtine
              wow! that is weird! but thanks to let me know how you fixed it. I wouldn't have though of a reboot to fix it!
