    [Plugin] Rotated Circle/Cylinder
    14 Posts 12 Posters 10.9k Views 12 Watching
    • sdmitchS Offline
      sdmitch
      As requested. Rotated Circle/Cylinder allows you to define the center of the circle or cylinder, the axis that it is oriented on or along, and the radius of the circle or cylinder. All in three clicks.
      Version 1.1 Double clicking on a face defines the direction as perpendicular to the face. Use Ctrl key on PC's to toggle grouping on and off. On MAC's, use the Alt key.
      Version 1.2 The groups axes are aligned to the direction defined.
      Version 1.3 Made 2014 compliant.
      Please get the latest version from the PluginStore
      http://sketchucation.com/pluginstore?pln=Rotated_Circle_Cylinder
      http://sdmitch.blogspot.com/
        The video tutorial is here πŸ˜‰
        • gillesG Offline
          gilles
          A pure gem.
          • pbacotP Offline
            This is great. Many thanks Sam!
              the.pjt
              wow ... thanks sam , thanks
                Trogluddite
                Many thanks - that's a real time saver! πŸ‘
                  a4chitect
                  nice little thing, thanks
                  would be nice if it could automatically align the circle normal with the face normal when double clicked on the face
                  face
                  single click> origin --> define circle normal by mouse
                  double click> origin & circle normal == face normal
                  • utilerU Offline
                    utiler
                    Should be part of the 'out of the box' tools!!!!!
                    Well done, Sam! πŸ‘
                    Just Curious...
                    • sdmitchS Offline
                      sdmitch
                      Version 1.1 has been posted. Double clicking on a face defines the direction as perpendicular to the face.
                        davecoopstl
                        Version 1.1, with double-click to create the cylinder perpendicular, is FANTASTIC.
                        Are you going to update this feature (as well as the updated Rotate Box tool) in the 3_Points Tool pack?
                        Just curious.
                        Dave.
                          Michaelv
                          Just curious.
                          Dave.
                          Done!
                          • EarthMoverE Offline
                            EarthMover
                            Another gem! Thanks Sam.
                            Content Creator at Skapeup
                              jorge2011
                              thank you very much. excellent plugin.
                              you can add the same options of the tool box rotated?
                              1 - Align axes of the group, in the center of the circle.
                              2 - exchange with the CTRL, between geometry and geometry grouped ungrouped?
                              thanks
                              • sdmitchS Offline
                                sdmitch
                                Version 1.2 has been posted. The axes of the group is aligned with the defined direction.
