    Shared layer trouble
    3 Posts 2 Posters 215 Views 2 Watching
    • I
      Involute
      In the attached file, I've created some short, square supports on layer Support 3. I've copied two of these and placed them on layer Support 5. When I toggle Support 5 visibility, the two copies (and nothing else) turn on and off as they should. When I toggle Support 3 visibility, however, all the originals on Support 3 turn on and off (as they should), but so do the two copies on Support 5, as if they're on layer Support 3 and Support 5. How do I fix this so the copies I put on Support 5 only toggle with that layer? Thanks.
      Sketch.skp
      • pbacotP
        I used the plugin "default layer geometry" http://forums.sketchucation.com/viewtopic.php?f=323&t=7638&start=0 (select all and run plugin). It seems to work if I understand your setup properly. Apperently some of the raw geometry was on a layer other than Layer0 where it all belongs.
        • I
          Involute
          Cool. That did it. Thanks.
