    Texture change with bends and turns plugin?
    3 Posts 2 Posters 230 Views 2 Watching
    • 3 Offline
      3di
      I was making road/bike path/walking path and noticed that i couldn't change the texture with the road that if i had it bend or turn it wouldn't turn or bend with it. Has anyone made a plugin that can change the textures inside the road to match the changing bends and turns? Thank you for your time.
        Textures do not "bend". You can subdivide a face and apply a texture so that the pieces look like it is bent. There's a tutorial here: http://forums.sketchucation.com/viewtopic.php?f=18&t=34072
        Also, there is a relatively new plugin that helps with this kind of matters: http://forums.sketchucation.com/viewtopic.php?t=44501
        • 3 Offline
          3di
          This is great stuff thank you for the help and information.
