    Given a [x,y,z] delete a text note. Need help, Solved
    8 Posts 3 Posters 687 Views 3 Watching
    • dukejazzD
      dukejazz
      I have a update going and I have two problems to solve for
      scaleGroupFloat v1.2 bata
      WIP
      Is there a way in ruby code:
      1-given a xyz make a point +
      2-given a xyz delete a text note
      Need some help:
      1- best I can do is to draw a [x,y,z] center point vector line.
      2- I can make the note by [x,y,z] but, now I want to delete it by [x,y,z]
      ok
      Here my codes for 1 and 2 so far
      1)Sketchup.active_model.entities.add_line([0,0,0],[x,y,z])
      2)Sketchup.active_model.entities.add_text "a text note",(Geom::Point3d.new([x,y,z]))
      I need some helpful hints please.
      • TIGT
        You know the point
        pt=Geom::Point3d.new(x,y,z)
        You need to iterate the model's entities and find any text that is inserted at that very point and then erase it...
        model.active_entities.to_a.each{|e| e.erase! if e.is_a?(Sketchup::Text) and e.point==pt }
        πŸ€“
        • dukejazzD
          dukejazz
          I was a early programmer in the 80's not bad at machine code,Assemble,fortran and basic. Then in Sept of this year I relize that ruby was easy to learn. I starting to pick at the API. I no expert I know about 10 to 15% at this point.
          I will work in API index areas with code you have given me thanks
          • dukejazzD
            dukejazz
            My anser to question 1 is now solved: 😍
            Given a [x,y,z] make a point.
            API
            The position method is used to retrieve a Point3d used to create a construction point.
            Sketchup.active_model.active_entities.add_cpoint Geom;;Point3d.new (x,y,z)
            Thanks for the hint TIG
            • Dan RathbunD
              Dan Rathbun
              .. but do not put spaces between the method name and the ( of the argument list.
              I'm not here much anymore.
              • dukejazzD
                dukejazz
                I thank your right
                so I check my work
                API notes has this space too?
                Entities.add_cpointSketchUp 6.0+
                The add_cpoint method is used to create a construction point.
                model = Sketchup.active_model
                entities = model.active_entities
                point1 = Geom::Point3d.new (100,200,300)
                constpoint = entities.add_cpoint point1
                if (constpoint)
                UI.messagebox constpoint
                else
                UI.messagebox "Failure"
                I used this in this form in my program
                Sketchup.active_model.active_entities.add_cpoint Geom::Point3d.new (dj_x1[9],dj_x1[10],dj_x1[11])
                edit for here
                Sketchup.active_model.active_entities.add_cpoint Geom::Point3d.new (x,y,z)
                you say
                Sketchup.active_model.active_entities.add_cpoint Geom::Point3d.new(x,y,z)
                both two form works.
                Thus I will concude
                Geom Classes allow a space
                wild other Classes don't allow
                Here the correction.
                • TIGT
                  pt = Geom::Point3d.new 100, 200, 300
                  this currently works, and it is used in most of the API examples... BUT it might be deprecated in future versions of Ruby, so using '(' and ')' [parentheses] to enclose a methods argument[s] is always recommended, as shown below...
                  pt = Geom::Point3d.new(100, 200, 300)
                  • this is the preferred method - note how the opening '(' comes immediately after the method with NO space.
                    Using a space like this...
                    pt = Geom::Point3d.new (100, 200, 300)
                    can cause errors reports, although it might work some of the time... BUT it's always best to avoid a space before the opening '(' !
                  • dukejazzD
                    dukejazz
                    Its a new day and I tried the code again.
                    the code works!
                    TIG on Fri Jun 01, 2012 6:35 am
                    #first note written some min early.....
                    Sketchup.active_model.entities.add_text "Text note 1",(Geom::Point3d.new(x1,y1,z1))
                    #-Given a [x,y,z] delete a text note.
                    #erase note 1
                    Sketchup.active_model.active_entities.to_a.each{|e|
                    e.erase! if e.is_a?(Sketchup::Text) and e.point==Geom::Point3d.new(x1,y1,z1)
                    #-Thus Given a [x,y,z] delete a text note...Solved by TIG
                    #New note 2 written by it self
                    Sketchup.active_model.entities.add_text "Text note 2",(Geom::Point3d.new(x1,y1,z1))
                    Ya! Ho!
