[code] Cleanup After execute_script
This code cleans-up the cruft left behind when using execute_script. (reference thread)
Chris' version: (http://forums.sketchucation.com/viewtopic.php?p=274499#p274499)
function corePurge(){ coll = document.body.childNodes; for(a=0; a < coll.length; a += 1){ if (coll[a].tagName === "SCRIPT" && coll[a].id === ""){ document.body.removeChild(coll[a]); a -= 1; } } }My version:
function purge_script_tags() { var b = document.body; var last_node = b.lastChild; while(last_node.nodeName === "SCRIPT") { b.removeChild(last_node); last_node = b.lastChild; } } -
jQuery version:
$('body script').detach(); -
@jim said:
My version:
function purge_script_tags() { > var b = document.body; > var last_node = b.lastChild; > while(last_node.nodeName === "SCRIPT") { > b.removeChild(last_node); > last_node = b.lastChild; > } > }This would remove all last scripts including ones not by
execute_script- UHMS -
And in Chris' edition.. if a developer wanted to avoid being cleaned up, he need only set an id attribute on the script object.
