    [code] Cleanup After execute_script
    4 Posts 4 Posters 1.3k Views 4 Watching
      Jim
      This code cleans-up the cruft left behind when using execute_script. (reference thread)
      Chris' version: (http://forums.sketchucation.com/viewtopic.php?p=274499#p274499)
      function corePurge(){
         coll = document.body.childNodes;
         for(a=0; a < coll.length; a += 1){
            if (coll[a].tagName ===   "SCRIPT" && coll[a].id === ""){
               document.body.removeChild(coll[a]);
                              a -= 1;
      My version:
      function purge_script_tags() {
        var b = document.body;
        var last_node = b.lastChild;
        while(last_node.nodeName === "SCRIPT") {
           b.removeChild(last_node);
        jQuery version:
        $('body script').detach();
        • chrisglasierC Offline
          chrisglasier
          @jim said:
          My version:
          This would remove all last scripts including ones not by execute_script - UHMS
          • Dan RathbunD Offline
            Dan Rathbun
            And in Chris' edition.. if a developer wanted to avoid being cleaned up, he need only set an id attribute on the script object.
            I'm not here much anymore.
