    Plugin that removes inner faces/edges from intersected mesh?
    3 Posts 2 Posters 312 Views 2 Watching
    • N Offline
      nickdk
      I keep having issues with outer shell. Even simple geometry doesn't intersect correctly like in the attached screen-dumps.
      Is there an easy way to remove the 'inner' edges and faces that will remain after an intersect or outer shell command?
      I really don't understand why I have so many issues with outer shell, I have tried to scale x 100 and the results are the same.
      but since it doesn't work I have to do much manual removal after i have intersected the geometry correctly :S
        Try this:
        http://forums.sketchucation.com/viewtopic.php?t=12668
        • N Offline
          nickdk
          @gaieus said:
          Try this:
          Thanks Gaieus πŸ˜„
