    Problem with "instant road"
    10 Posts 8 Posters 7.0k Views 8 Watching
    • 1 Offline
      19marco23
      Hello everyone, I follow you a long time and I must thank you because you have enlightened me on many things about this super program! Today I find myself having to create a new job, as you can see the files I attached, I contour and should create for ourselves on a grid of streets. I tried using the plugin "instant road" but I can not do anything, always gives me error. I also tried with "super drape" but the result is not good. I know how to give some advice? If you purchase the paid version of "instant road" you think I can solve?
      Sorry for my English. I hope I was clear in the explanation.
      Regards, Mark.
      curve di livello_1.rar
      • brookefoxB Offline
        brookefox
        Marco,
        Just an initial suggestion: Make it easier on the reader: Post a pic as well as an skp, rather than a rar file, so we can see your problem without opening anything other than this thread, but we can open your model with one click if we want to.
        What specifically is your problem and error?
        As I recall 'instant road' is limited to a 6' width or something like that, but yes I would be sure it worked at that width before upgrading. You might post direct to author Chuck Vali, who is quite responsive, I think, and is listed in the plugin directory.
        ~ Brooke
        • charly2008C Offline
          charly2008
          I've tried it. I exploded the group and created a new group. But then there is a new problem.
          • 1 Offline
            19marco23
            Hello guys, thanks for the answer. I also received help from the forum of architects and valid at the time I solved it by splitting the road in many parts. When I have the final version of the prominence will adapt the land and will cover the various errors with the vegetation.
            I'll post a picture as soon as possible.
            Thanks for now, good day.
              smhbrv
              Hi everyone.
              I am an architect in Turkey.
              I model my terrain but I dont put my road in my terrain.
              It gives an error. (Unable to triangulate road surface. Try using smaller max road Segment Lenght.)
              I try lots of times but it gives same error.
              http://1.1m.yt/z6LbBUo.jpg
              Please look at attachment. Pls help me.
              11.skp
              • Bob JamesB Offline
                Bob James
                Just use Push-Pull on the road system and intersect with the terrain.11R.skp
                  smhbrv
                  @bob james said:
                  Just use Push-Pull on the road system and intersect with the terrain.[attachment=0:1gqriwfi]<!-- ia0 -->11R.skp<!-- ia0 -->[/attachment:1gqriwfi]
                  I try to work with levels/grade. I dont do this. Ways stand on the levels/grades. ?? 😞 😞
                  Please help me.
                    Or Sand Box / Project very more speedy than PushPull/Intersect! 💚
                    And here the file V6 of Bob!
                    It's a very good habit to save as V6 for a more large audiance! 👍
                    And more light! 😉
                    11R.skp
                    • pbacotP Offline
                      You can always talk to Chuck at Valiarchitects regarding Instant Road. He developed Instant Terrain to help with difficult terrain models, but I don't know if that's your problem. May be a communication barrier to overcome.
                        rwn
                        Bom dia galera, preciso de ajuda com o plug-in instant road.
                        Não estou conseguindo aumentar a largura da rua junto com as calçadas para o projeto que tenho, estou tentando deixar a rua com 8metros de largura e 2metros de cada lado de calçada, más até agora não obtive sucesso.
                        Se alguém souber e puder ajudar, ficarei grato.
