    MongoDB in plug-ins for SketchUP
    5 Posts 2 Posters 1.2k Views 2 Watching
    • yad2000Y Offline
      yad2000
      Does anyone have any example of using the plug-in database MongoDB. Or maybe open a branch of the discussion on this issue?
      CoolPipe Plugin
      • yad2000Y Offline
        yad2000
        I've thought and thought and come to the conclusion that it is enough to have a database of the form
        db = [{;Header=>[{;Name=>"My DB",
                          ;Type=>"some"}],
               ;Body=>[{;element_ID1=>[{;key1=>value1,
                                        ;key2=>value2}],
                        ;element_ID2=>[{;key1=>value3,
                                        ;key2=>value4}]}]}]
        it's good when the values ​​of such a maximum of 100, and if they are 10, 000, and if they are not constant, to make changes to such a database is quite a difficult task.
        but still, I want to use ready-made solutions. Is not it possible that no one faced with this problem?
        MongoDB or impossible to use in this implementation, Ruby. I would be grateful for any response on this topic ...
        CoolPipe Plugin
        • yad2000Y Offline
          yad2000
          apparently no one is never used, or the topic is not very much relevant. too bad 😞
          CoolPipe Plugin
            Never had to use a DB with SketchUp plugins, no. πŸ˜•
            • yad2000Y Offline
              yad2000
              I started using the CSV database. topic can be closed
              CoolPipe Plugin
