    DC with elevation and tilt
    4 Posts 3 Posters 1.2k Views 3 Watching
    • Epix3DE
      Epix3D
      Having problem with this DC trying to make a menu for Height and tilt option.
      What I want it to do is that when you click on the side bracket you can adjust height, -and when you click on the footrest plate you can adjust tilt.
      Preferably this would also be choices in the menu.
      Can anybody help me with this?
      http://www.epix.no/uploads/Dynamic Components/12599Footrace.jpg
      I also have a question about editing the image in the component option menu . If I start modelling from blueprints model lying on the ground it will be viewed from lying position even if it was standing on ground when making the option menu..?. (..this is another model I made)
      Is there a way to change/update the image?
      http://www.epix.no/uploads/Dynamic%20Components/12599Footrace.skp
      • J
        Jim
        Here's one way. I had to animate an attribute in the parent component from the child component. Then the attribute can be used by both movements.
        (I broke the dialog, but the "Finger" tool works to animate.)
        12599Footrace (1).skp
        • Epix3DE
          Epix3D
          Thank you Jim.
          • A
            Alanwhughes
            this is the closest dynamic component to the one I am trying to create,
            I need a window to first tilt inward by 10 degrees, and then close again, and then the next time you click, to then turn inward by 90 degrees...
            like this example, can this be done by clicking on the same part of the window? or does it involve creating parent and child elements and clicking on a different part of the model to get it to do one or the other...
            I don't really want to be able to turn and then whilst it's open, also be able to tilt !
            so anyone know of an existing model out there? or help me to put one out there..
            Cheers,
            Al
