    Basic operation on char...
    16 Posts 2 Posters 801 Views 2 Watching
    • N
      njeremy2
      Hello everyone ! 😄
      I have a stupid question but I can't find the solution...
      I would like to retrieve a string until " " (space) from description of component.
      %(#008000)[MY example :
      Definition : Cube
      Description : 755480RED That's my cube]
      755480RED is a reference of the cube and "That's my cube" the real description.
      I just need to retrieve the reference include in the description.
      description = Sketchup.active_model.description
      Sketchup.active_model.entities.each do |entities|
      @tab << entities
      	@tab.each do |element|
      		UI.messagebox "#{element.description}".to_i
      	end #end TAB.EACH
      end #model.each
      Here,
      when I put : UI.messagebox "#{element.description}" I have the complete description.
      when I put : UI.messagebox "#{element.description}".to_i I have only the first number (it works only if the reference are numbers only)
      What I need is to put a condition which is:
      Retrive the description until you found " " but I don't know how to do that.
      Someone can help me ?
      • thomthomT
        element.description.split(' ')[0]
        Reference: String#split
        • thomthomT
          Btw, did you create the component? Is it intended for the user to read that reference code?
          If not, then you might want to store it in an attribute:
          Entity#get_attribute: https://developers.google.com/sketchup/docs/ourdoc/entity#get_attribute
          Entity#set_attribute: https://developers.google.com/sketchup/docs/ourdoc/entity#set_attribute
          class AttributeDictionary: https://developers.google.com/sketchup/docs/ourdoc/attributedictionary
          class AttributeDictionaries: https://developers.google.com/sketchup/docs/ourdoc/attributedictionaries
          • N
            njeremy2
            Yeahhh !! thanks thomthom !!
            I searched in french tutorials, that's why I didn't found anything !! lol
            • N
              njeremy2
              no no ! it's ok !
              Components are already create when I put components in design I launch my plug test.
              My plugin search all components and then I ask it to display each references include in their description
              • N
                njeremy2
                Sorry I don't understand the first time I read your post...
                I can use attributes but I see in AUTOMATIC Sketchup.pdf that's attributes cannot be stored when you save a component (I understand that)
                And put the reference into the description was for me the easiest solution (I hope, if someone has a better solution, tell me).
                In that way, I'm sure the reference is shared when I sent a component to my database
                • thomthomT
                  If you store attributes with the definition then you can export the component with the attributes.
                  Example:
                  componentinstance.definition.set_attribute('MyTest', 'Foo', 'Bar')
                  Export component
                  New model
                  Import exported model
                  componentinstance.definition.get_attribute('MyTest', 'Foo')
                  ( returns 'Bar' )
                  • N
                    njeremy2
                    hmmmm, well...
                    With that, you can add an attribute called "reference" for all components and set attribute then ?
                    So if I do like that : componentinstance.definition.set_attribute('Reference', '755480RED', 'Valuedefaultif 755480RED doesnt exist')
                    That would work ?
                    And to list all references, how should I do ?
                    componentinstance.definition.set_attribute('Reference') ?
                    • thomthomT
                      Read the API docs again.
                      set_attribute takes three arguments. The third one is the value.
                      entity.set_attribute( 'DictionaryName', 'Key', 'Value' )
                      entity.get_attribute( 'DictionaryName', 'Key' )
                      So, if you do something like to to add a reference ID:
                      entity.set_attribute( 'nJeremy2', 'Reference', referenceID )
                      You can list all definitions with a reference set like so:
                      <span class="syntaxdefault"><br />for definition in Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />  next if definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">image</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  next if definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  referenceID </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'nJeremy2'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Reference'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  next if referenceID</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Do something to the definition here...<br /></span><span class="syntaxdefault">end<br /></span>
                      • N
                        njeremy2
                        yeah ok !
                        I will try but the result is not guarantee
                        • N
                          njeremy2
                          my solution by putting the reference in description work, it isn't good programming but it works lol
                          thank you thom !
                          • thomthomT
                            What if your user accidentally modify the description? Or some other plugin the user has install modifies it?
                            • N
                              njeremy2
                              right...
                              But I try to use attributes, but I cannot do it right
                              • thomthomT
                                What is not working right?
                                Do you have a sample code?
                                When assigning an attribute to the definition the attribute is stored whenever you export - it works fine. But if it doesn't work for you then it's probably something in your code that isn't quite right.
                                • N
                                  njeremy2
                                  I have nothing at home, tomorrow I'll show you what I need to do with that (with screenshots)
                                  • N
                                    njeremy2
                                    For this example I put a tree and a Blue cube.
                                    The tree has no description and the Cube has code reference then the real description after "b755480 BLABLABLA".
                                    Then I create a groupe with the 2 objects called "Tree+cube"
                                    http://img840.imageshack.us/img840/23/designpx.png
                                    Now I export all information with my plugin :
                                    http://img689.imageshack.us/img689/8130/exports.png
                                    then I export all information in CSV File :
                                    http://img804.imageshack.us/img804/2953/exportcsv.png
