    Basic operation on char...
    16 Posts 2 Posters 868 Views 2 Watching
    • N
      njeremy2
      @thomthom said:
      Btw, did you create the component? Is it intended for the user to read that reference code?
      If not, then you might want to store it in an attribute:
      Entity#get_attribute: https://developers.google.com/sketchup/docs/ourdoc/entity#get_attribute
      Entity#set_attribute: https://developers.google.com/sketchup/docs/ourdoc/entity#set_attribute
      class AttributeDictionary: https://developers.google.com/sketchup/docs/ourdoc/attributedictionary
      class AttributeDictionaries: https://developers.google.com/sketchup/docs/ourdoc/attributedictionaries
      no no ! it's ok !
      Components are already create when I put components in design I launch my plug test.
      My plugin search all components and then I ask it to display each references include in their description
      • N
        njeremy2
        Sorry I don't understand the first time I read your post...
        I can use attributes but I see in AUTOMATIC Sketchup.pdf that's attributes cannot be stored when you save a component (I understand that)
        And put the reference into the description was for me the easiest solution (I hope, if someone has a better solution, tell me).
        In that way, I'm sure the reference is shared when I sent a component to my database
          If you store attributes with the definition then you can export the component with the attributes.
          Example:
          componentinstance.definition.set_attribute('MyTest', 'Foo', 'Bar')
          Export component
          New model
          Import exported model
          componentinstance.definition.get_attribute('MyTest', 'Foo')
          ( returns 'Bar' )
          • N
            njeremy2
            hmmmm, well...
            With that, you can add an attribute called "reference" for all components and set attribute then ?
            So if I do like that : componentinstance.definition.set_attribute('Reference', '755480RED', 'Valuedefaultif 755480RED doesnt exist')
            That would work ?
            And to list all references, how should I do ?
            componentinstance.definition.set_attribute('Reference') ?
              Read the API docs again.
              set_attribute takes three arguments. The third one is the value.
              entity.set_attribute( 'DictionaryName', 'Key', 'Value' )
              entity.get_attribute( 'DictionaryName', 'Key' )
              So, if you do something like to to add a reference ID:
              entity.set_attribute( 'nJeremy2', 'Reference', referenceID )
              You can list all definitions with a reference set like so:
              <span class="syntaxdefault"><br />for definition in Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />  next if definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">image</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  next if definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  referenceID </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'nJeremy2'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Reference'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  next if referenceID</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Do something to the definition here...<br /></span><span class="syntaxdefault">end<br /></span>
              • N
                njeremy2
                yeah ok !
                I will try but the result is not guarantee
                • N
                  njeremy2
                  my solution by putting the reference in description work, it isn't good programming but it works lol
                  thank you thom !
                    What if your user accidentally modify the description? Or some other plugin the user has install modifies it?
                    • N
                      njeremy2
                      right...
                      But I try to use attributes, but I cannot do it right
                        What is not working right?
                        Do you have a sample code?
                        When assigning an attribute to the definition the attribute is stored whenever you export - it works fine. But if it doesn't work for you then it's probably something in your code that isn't quite right.
                        • N
                          njeremy2
                          I have nothing at home, tomorrow I'll show you what I need to do with that (with screenshots)
                          • N
                            njeremy2
                            For this example I put a tree and a Blue cube.
                            The tree has no description and the Cube has code reference then the real description after "b755480 BLABLABLA".
                            Then I create a groupe with the 2 objects called "Tree+cube"
                            http://img840.imageshack.us/img840/23/designpx.png
                            Now I export all information with my plugin :
                            http://img689.imageshack.us/img689/8130/exports.png
                            then I export all information in CSV File :
                            http://img804.imageshack.us/img804/2953/exportcsv.png
