    Rendering with SU and Plug-in
    3 Posts 2 Posters 267 Views 2 Watching
    • E
      eccowboy
      I need help, when I cut a section through a building and render it the front of the building still shows.
      I'm using a plug-in. When I render the exterior it's ok when I use the plug-in. BUT when I render it doesn't always
      show the rendering that I what. It's becoming frustrating using the plug-in ans Sketchup. With your reply
      PLEASE right down the correct steps. It ONLY happens when I use the plug-in.
      Thanks,
      Eccowboy
      • E
        Ecuadorian
        Most render plug-ins will not render a section cut, so you'll have to use this trick:
        http://forums.sketchucation.com/viewtopic.php?f=18&t=21963
        -Miguel Lescano
        • E
          eccowboy
          I figured it out.....if I make a scene in SU...I can render it using my plug-in and renderings look great..
          Thanks...
