    [REQ]Reset scale multiple components
    9 Posts 2 Posters 1.0k Views 2 Watching
      baldaman
      If I select only one component, I can reset scale with right click, If I select two components, this option disappear...
      Maybe is it possible to do that with code?
      • sdmitchS Offline
        sdmitch
        Check out my Reset Scale plugin on my blog.
        http://sdmitch.blogspot.com/
          baldaman
          Thank you sdmitch, I downloaded it and installed it but it appears that if the components have been modified by CHris fullmer's plugin "Scale and rotate multiple" it doesn't work.
          It works well if components have been modified with Sketchup's native scale tool...
          If I use scale_reinit.rb
          http://forums.sketchucation.com/viewtopic.php?t=11552
          it works even with components modified with CHris fullmer's plugin "Scale and rotate multiple"
          but of course the components come back to their original orientation...
          I do not care about orientations issues in today's case, but I just wanted to inform you, thank you again!
            baldaman
            UPDATE: with scale_reinit.rb the components go back to their original sclae and orientation but they are moved away from their original poisition...
            even if the component's axes are right in the middle of the object
            • sdmitchS Offline
              sdmitch
              I think that is because scale_reinit assumes the default lower left component origin.
                baldaman
                Ah OK, do you think that it is possible to change the code to assume the bonding box center origin?
                • sdmitchS Offline
                  sdmitch
                  I don't see why not but maybe you had better ask Chris about that.
                  • sdmitchS Offline
                    sdmitch
                    With apologies to Chris, you might try changing this line
                    Sketchup.active_model.active_entities.add_instance(ent.definition,ent.bounds.corner(0))
                    to this
                    Sketchup.active_model.active_entities.add_instance(ent.definition,ent.bounds.center)
                      baldaman
                      Thank you very much!
                      It works now!
