    Mystery
    4 Posts 3 Posters 252 Views 3 Watching
      Michaelv
      So I'm writing a script, nothing too fancy.
      It's not fully working yet, but functionally it is (some methods are puts instead)
      The mystery is that every time the script ends, at the time I select the selection tool I get this message in the console:
      Error: #<ArgumentError: wrong number of arguments (1 for 0)>
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:155:in `deactivate'
      Needless to say I have the traductor and the LIBFREDO_Dir, bu I am in no way calling them within the script, nor sending ay instruction that should create this.
      Also my script end is a standard deactivate method as follows:
      def deactivate
      Sketchup::set_status_text("",SB_PROMPT)
      Sketchup::set_status_text("",SB_VCB_LABEL)
      Sketchup::set_status_text("",SB_VCB_VALUE)
      I'm on a MAC
      Anybody can help? Fredo?
        Are all of your methods wrapped inside a module and/or class ?
        I'd be surprised that Fredo has a raw 'deactivate' method πŸ˜• I suspect you do !
        It might be an observer trapping your error into his own error reporting, assuming it's his tool's error...
        The standard Tool deactivate method is
        def deactivate(**view**)
        ...Try adding that inside a Tool class...
        https://developers.google.com/sketchup/docs/ourdoc/tool#deactivate
        • Dan RathbunD Offline
          Dan Rathbun
          It looks to me as not.
          He is defining a global method deactivate within Object, and it's getting inherited by EVERYTHING, including Fredo's modules.
          I'm not here much anymore.
            Michaelv
            YES! That did it!
            Yes it was all within a class. Just adding "(view)" solved the problem. I didn't change anything else. The deactivate method was within the class and still is.
            Yes indeed I strongly suspected that Fredo had nothing to do with this.
            Thanks TIG and Dan.
