    Where to Find Shiny Metalic Coloring?
    7 Posts 3 Posters 2.0k Views 3 Watching
    • BSquared18B Offline
      BSquared18
      I'm at the point of wanting to apply a shiny, metallic, aluminum-looking finish to an airplane I'm building. The metallic textures that come with SketchUp are very limited. I've found some nice-looking .igm and .pigm files that I could download from websites. Can they be used in SketchUp? If yes, how is that done? If no, where can I find shiny metal textures?
      Thanks,
      Bill
      • numbthumbN Offline
        numbthumb
        Are you going to render it? You can apply such materials inside rendering app.
        Like here:
        http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=98
        http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=20
        Comfortably numb...
        • Alan FraserA Offline
          Alan Fraser
          Yes, it's certainly possible to make nice shiny models in SU...but as numbthumb states, you'll need to render them in a 3rd Party renderer.
          http://www.formfonts.com/files/1/16130/kitchenaid-series-600-food-mixer-revit-format-added_FF_Model_ID16130_1_katn.jpg
          Native SU output is non-reflective. You can fake this with custom-made textures using painted highlights, but that will require quite a bit of work, a lot of skill and a decent paint program.
          http://www.formfonts.com/files/1/12787/the-new-fiat-500-designed-2007-years-after_FF_Model_ID12787_4_Fiat_500_Tx3_00.jpg
          3D Figures
            BSquared18
            Are there any free rendering programs you would recommend, or, failing that, any low-budget ones?
            Bill
              numbthumb
              Kerkythea is free, but maybe not that user friendly.
              If you´re not going to spend too much money, try Twilight render. There is a demo version, although wuith a limited resolution output, but quite enough for a start.
              Anyway, check this out: http://forums.sketchucation.com/viewtopic.php?f=81&t=3220
              Comfortably numb...
                BSquared18
                Thanks, N.T. Very helpful.
                Bill
                  numbthumb
                  No problem. And post your progress 😉
                  Comfortably numb...
