    Changing distance by changing several dimensions at once
    3 Posts 2 Posters 245 Views 2 Watching
    • ipsketchpiI
      ipsketchpi
      Is there any chance to make equal distance between several parts our components by changing dimension, saying for example EQUAL, like it is in Solid Works for example?
      sample
      /IP
      • Alan FraserA
        Alan Fraser
        Dynamic Components will do exactly what you want. Open the DC Sampler in your component browser and load the sample picket fence. Make sure you have the Dynamic Component toolbar loaded (View menu > Toolbars > Dynamic Components). Then select the fence component and choose the Component Options on the DC toolbar. Change the default spacing from 5" to something longer, then stretch the fence section to a more realistic length using the Scale tool.
        I see you are using the Pro version, so with a little reading you can make your own custom components.
        You can, of course, simply array a component along a path at equally spaced intervals...but I read your question as if you want to re-array elements that are already in place.
        3D Figures
        • ipsketchpiI
          ipsketchpi
          thank you Dynamic Components will be what I need
          /IP
