    [Plugin] Spritely v0.1
    6 Posts 6 Posters 7.9k Views 6 Watching
      Diggsey
      This plugin lets you create sprites from your models. It's primarily intended for tile-based games, so it uses an orthographic camera but you can choose the viewing angle and things like that.
      How to use:
      • Click the "Select Tile" tool and select the rectangle which would be the tile below your model.
      • Click the "Capture Sprite" tool to generate the images.
      Features:
      • Supports transparency
      • Images are antialiased
      • Images from different angles are all aligned correctly
      • Can generate a single image or images from all angles
      It uses the default sketchup renderer, but you could theoretically plug-in any renderer which used sketchup's camera settings.
      Example output (9 images from 32 generated):
      http://forums.sketchucation.com/download/file.php?mode=view&id=87149&sid=3642022df9db93e60e165ff8e87ca727
      spritely.zip
      • MikeG73M Offline
        MikeG73
        Thanks Mate, superb Idea!!!
        • iichiversiiI Offline
          iichiversii
          Fantastic πŸ˜„
          Bring on the Rain...
            Game builder! β˜€
            • F Offline
              Fred_Flintstones
              Love it.
              Time to make a 2D game πŸ˜„
                akirastudio
                i've downloaded but doesn't work on mac...
