[Plugin] Spritely v0.1
This plugin lets you create sprites from your models. It's primarily intended for tile-based games, so it uses an orthographic camera but you can choose the viewing angle and things like that.
How to use:
- Click the "Select Tile" tool and select the rectangle which would be the tile below your model.
- Click the "Capture Sprite" tool to generate the images.
Features:
- Supports transparency
- Images are antialiased
- Images from different angles are all aligned correctly
- Can generate a single image or images from all angles
It uses the default sketchup renderer, but you could theoretically plug-in any renderer which used sketchup's camera settings.
Example output (9 images from 32 generated):
Thanks Mate, superb Idea!!!
Fantastic
Game builder!
Love it.
Time to make a 2D game
i've downloaded but doesn't work on mac...
