    Scale model converter.
    2 Posts 2 Posters 424 Views 2 Watching
    • S
      stormwraith58
      Hi all. my name is Michael and I am new here and to sketchup. I hope that you all are doing great.
      I was wondering if this script might already exist. A script with a drop down menu that would automatically scale a model from full size to modeling scales based on your choice on the menu. also that would convert from one scale to another. such as 1:72 to 1:48 or 1:50 and so on.
      I do this already by making the life size. Then i take out my calculator and do the math. then go back to Sketchup and reduce the model to the finish scale. Let me tell you that takes for ever. lol Hope to hear from you guys soon. have an awesome day.
      Thank you all.
      Michael πŸ˜„
      • TIGT
        You haven't really explained why you are doing this.
        Is it something like you model an aircraft full size and then want to have a dimensioned 1/12 scale model?
        If so then do this...
        Make sure you are in the model entities context [i.e. not editing a group etc]
        Draw a line 12" long [assuming you are using inches].
        Use the Tapemeasure tool and click the two ends of the line.
        The VCB should show 12".
        Immediately type 1" + <enter>.
        You are asked if you want to scale the model.
        Answer 'Yes'.
        The line and the rest of the model are now 1/12 the size they were...
        Erase the unneeded line.
        To make other scalings from a full sized version simply draw the line an appropriate length, so for 1/48 use a 48" line scaling down to 1"...
        A tool listing all the possible scales will take as long to use as this simple method and of course it's probably not have the scale you wanted in the list anyway!
        To reverse the scaling... let's assume 1/12... draw a line 1" long, Tapemeasure pick its end and type 12" etc, and everything is scaled back to full-size again...
