    [REQ] Click Copy Rotation-Released
    12 Posts 3 Posters 867 Views 3 Watching
      Edit : you can find it here on the fabulous Blog of SDmitch! πŸ‘
      Copy Rotate
      If not yet existing
      Select one object Input " DegreΒ° of rotation"
      Copy / Move with repeatitive rotation at each mouse click
      Here at each click there is a copy (+ move as the mouse moves) and a 30 Β° rotation
      • sdmitchS Offline
        sdmitch
        Do you want the copy to be inserted at and rotated around the picked point?
        http://sdmitch.blogspot.com/
          Jim
          Sounds like this: http://forums.sketchucation.com/viewtopic.php?t=11143
            Sounds like this
            Not exactly πŸ˜„
            Yes like this
            Select an object
            Call plug / Initialisation of the plug
            First click on the object is the position of the insertion object
            Degre asked
            Then the plug can run
            Inserted at the mouseclick point position + rotation degre asked
            So if the rotation asked was 10 Β° at the beginning of the call plug
            and if it's the 5th click since the running of the plug, (first click don't count of course)
            object must be rotated by 50Β°
            6 objects must drawn from the beginning, an original
            and 5 copy anywhere on the screen where the mouse was clicked
            • sdmitchS Offline
              sdmitch
              Works like a charm! πŸ‘
              Just 2 little things
              Ctl + Z exit and dont erase the last drawn object << Esc key
              The helper text appears before the Snap point << ??? You want to pick the Component/Group first then get the "Rotate by:" prompt?
              Very cool for make random tilling controled! β˜€
                Bravo! β˜€
                Just 2 little things πŸ˜„
                The helper text appears before the Snap point (and snap point genarally don't appears)
                but not really a problem because Helper text is always working!
                • sdmitchS Offline
                  sdmitch
                  Not sure why but I don't have that problem.
                    All works fine, it's just the snap point who is not visible!
                    Helper text appears but not the snap point!
                    That makes the same for the selection of the first point of insertion!
                    That is not really a problem, that is just curious πŸ˜„
                      I was on V7
                      I will try on a v8 version πŸ˜„
                      Thanks again for the effort! πŸ‘
                      For the "take back" (erase the last object error )
                      I can just exit, kill the last drawn object, and remake a start! πŸ˜‰
                      • sdmitchS Offline
                        sdmitch
                        post deleted.
                          Sam makes it! 😎
                          You will can find it on his blog in no time! β˜€
                          Very cool blog, each Plug has a tuto video!
                          Select an object Group or Component
                          Select a rotation's degree (can be made on the fly during the clicks)
                          Select a point of reference on the object
                          Click anywhere you want, the object will be copy and increment rotated!
                          You can use Key BackSpace for erased previus objects
                          A cool one! πŸ‘
                            Released! 😎
                            Copy Rotate
