    Using View.draw_text method - a bug?
    3 Posts 2 Posters 519 Views 2 Watching
      johnwmcc
      I'm running SketchUp v8.0.11752 on Windows Pro 64bit, and trying to get my head round developing a new Tool to draw shapes using a variant of Jim Folger's CLineTool.
      At the moment, I'm trying to understand how to use the View.draw_text method when providing feedback to the user.
      The documentation says that the two arguments are a Point3D object, and a text string to display.
      When I test it using the [0,0,0] representation of a Point3D, the text is shown during the tool's operation at the SCREEN coordinates of [0,0] - right up at the top left of the SketchUp drawing area, NOT at the axis ORIGIN.
      Similarly, if I give it the (3D) input point at the cursor, the text moves with the cursor as expected, but around the top left screen position, going partially out of view some of the time. It seems to be taking only the r and g values of the 3D input point and displaying the text a proportionate amount of right and down displacement from the top left of the drawing viewport.
      Is this a bug? Or am I just not understanding how to feed the cursor location properly to view.draw_text? I'm using the same routine to draw test CLines, and they are starting in the right place both on screen and in the model.
      I've searched this forum, and Googled for view.draw_text, but can't find anything relevant other than the API documentation. I'm still very new to Ruby programming, and so far have only manage minor adaptations of other's code. At least I THINK I now understand how (almost) all of CLineTool works.
      But I don't find it easy to work out from the API docs how to use things for anything more complex than their (usually very simple) examples with static values, if I can't find another plugin that uses it. (And I do have a science and maths background to PhD level).
      Any help would be appreciated.
      John McC
        The position is a 2D viewport position wrapped in a Geom::Point3d object.
        If you have a 3D model position and want to get the 2D viewport representation of it, use view.screen_coords( point3d )
        <span class="syntaxdefault">pt3d </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">3 </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">pt2d </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">screen_coords</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> pt3d </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw_text</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> pt2d</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Hello World'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span>
        Yes - the API docs are lacking and often misleading or plain wrong sometimes. 😞
          johnwmcc
          Many thanks. For some non-obvious reason, I didn't even SEE the screen_coords method of the View object. I was looking for an equivalent method or property of the point itself.
          Gratefully....
          John MCC
